intercooler pump wiring
Good afternoon
My Callaway intercooler pump went bad. I bought a higher flow bosch pump and wiring kit from Lingerfelter they had a complete wiring kit and relay. the Callaway original relay and wiring has the black wire from the irc relay to the magnusom magnavolt hooked up directly. the Lingerfelter new irc harness has a green wire seperately. everything else looks the same. both companies use the magnusom blower. looking for some help on the wiring, or if someone has the lingerfelter wiring diagram for their coolant pump. sorry about it sounding confusing
found my answers! the black wire in the mutivolt shares the ground with the intercooler relay, it can be grounded anywhere. the green wire is the switched power wire that can be tapped into the fuel pump.
