C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
IGN1A Coils
Old 01-07-2017, 12:28 PM
  #61
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I am running e30 right now instead of e55 like normal because I had to get gas the other day on the way to work.
Also it is a chilly 55F outside, so maybe it is weather.
But so far, so good.
Old 01-07-2017, 12:35 PM
  #62
miami993c297
miami993c297's Avatar
Originally Posted by Unreal
Dwell time is a big table, not a specific setting. Like I said, did 10% over stock for now.
That I know, but what I do not know is what was the base table you bumped by 10%...
This is a Dwell table I tuned for the D-585:
Christian
Old 01-07-2017, 12:38 PM
  #63
Unreal
Unreal's Avatar
Top table is what I bumped by 10%. Not the modifier table.
And so far, my numbers are no where near that high. They still drop off a ton at upper RPM like stock.
Old 01-07-2017, 12:50 PM
  #64
stevieturbo
stevieturbo's Avatar
Apparently they keep creating more spark power even up to around 8-9ms dwell.
However....Lance seemed to imply with the dwell, we should be aiming for a spark duration target or something, which can depend on lots of other factors.
Not really sure how the average person is supposed to figure that one out, but he did seem to suggest even the 4.5ms I was running might have been too much.
Way over my head that...I'll leave it at that until there is a problem, I run a little more on a friends 4cyl car, but we were trying up to around 45psi boost on it and it seemed to do so without any spark problems. I think that was only around 5.5ms, but would need to check what I left it at.
Old 01-07-2017, 01:10 PM
  #65
Unreal
Unreal's Avatar
So should I run them flat dwell vs RPM or drop dwell as RPM increase.
Old 01-07-2017, 01:20 PM
  #66
stevieturbo
I run them at 4.5ms throughout.
Really if anything they would require more dwell under high load vs low load. That may not be rpm dependant.
But time per firing will decrease with rpm, but even at 4.5ms that leaves tons of time in between each firing even at 7, 8000rpm
No idea how the OEM ecu deals with dwell though, there would be no need or desire to overdwell the coils especially at low loads.
Some of Lances comments towards the end of this thread
http://ls1tech.com/forums/generation...ory-coils.html
Old 01-07-2017, 01:52 PM
  #67
Unreal
Unreal's Avatar
Factory table drops as rpm increases. I'll probably just flat line it then.
Old 01-07-2017, 01:55 PM
  #68
stevieturbo
I guess it depends what it is dropping from and to.
And whether the tables reflect actual dwell times at the coil, or some other set of calculations going on based on the table.
Old 01-07-2017, 02:01 PM
  #69
miami993c297
HPTuners gives you access to some Dwell modifier table, that can be useful...
Christian
Old 01-07-2017, 04:00 PM
  #70
Unreal
Unreal's Avatar
Just loaded a tune with dwell set to 4.4ms. Will see what that does. Pretty big increase over stock at most RPM value.
miami993c297 (01-07-2017)
Old 01-07-2017, 04:43 PM
  #71
stevieturbo
If that sounds like an increase...I'd query whether the numbers on the screen do actually mean that physical dwell time at the coil.
From what I gather, it's perfectly normal for most of the LS coils to be around 4-5ms ( just not the 585's )
Old 01-07-2017, 06:06 PM
  #72
Unreal
Unreal's Avatar
They are 4-5ms at low RPM and drop down to 2ms as RPM increase. the basically no change down low, with a big change up top.
Old 01-07-2017, 06:21 PM
  #73
stevieturbo
That seems very low up top, although I guess n/a they didnt have much need for a lot of spark or something
Old 01-07-2017, 06:41 PM
  #74
Unreal
Unreal's Avatar
So seems stronger. >4k the dwell is doubled so it should be getting more spark. Still have tr8ix at .028. Will maybe try gapping them up later.
For now, car runs damn good. Starts perfectly hot and cold, drives great.
Old 01-08-2017, 03:43 PM
  #75
neverstop
neverstop's Avatar
interesting the improvement is that noticeable. cool stuff.
Old 01-08-2017, 05:44 PM
  #76
Unreal
Unreal's Avatar
Power wise I don't think it did anything, but for idle/part throttle it seems to.
Quick Reply: IGN1A Coils
