Diagnosis - Stock LS7 Intake Manifold Cracked
I figured I would post in here since there are likely more people running an LS7 intake and forced induction than over in the C5 section.
I was doing some 60 to 160+ mph pulls yesterday on a runway and noticed some cracks on almost all of the reinforcing ribs of my LS7 intake where it bolts to the head. Manifold pressure was approximately 18psi. Has anyone seen failures in this area? Any idea what may have happened?
The heads have only had a clean-up mill and the intake was torqued using an inch pound torque wrench and the proper sequence.
WCCH did the heads. I had another stock LS7 intake on previously and no issues.
Strange freak failure.
My car this morning alone saw 24-25psi for 20-25 pulls. Not to mention the 1000+ 20+psi pulls without issue. I would throw another on and move on.
Great. I appreciate all of the input. I bought this one used so not sure what may have happened. I'll pull it off this week and see if maybe it was contacting the valley cover bolts. The plan is to hopefully pick up another used one for a good price and try again.
Another LS7 intake showed up this week so I finally got back to it tonight. Prior to unbolting, I set the wrench on 70 inch-lbs and it took a few pulls before the wrench clicked. Clearly the bolts were not overtorqued.
Also no obvious signs that the valley bolts were too tall and causing an issue. No marks or indentations on the bottom of the intake.
I'm not sure what else to check. You could see the plastic being relieved of stress as the bolts were loosened.
Here's a shot showing the valley cover bolts for reference.
As others suggested, check the intake does sit perfectly in the vee....in case either block deck or heads have not been machined quite correctly and there is a misalignment there.
Or maybe the intake itself had a slight manufacturing defect and was not perfect.
I had a different stock LS7 intake installed prior to this and it didn't have these issues.
Dyno on Friday. Plan is to add boost until it quits making power.
Received 1,194 Likes
St. Jude Donor '15
45psi
St. Jude Donor '15
I meant psig but was kidding
Following up and closing this one out.
I finished the intake swap Friday morning and went to the dyno. We made 6 pulls in the 18 to 23psi range with zero issues as far as the intake goes. There must have been a pre-existing condition with the other one.
Turbo-Geist (02-15-2017)
