Bad day at the track. Pulley on SC came loose
So first time at the track at Irwindale Ca. I've ran my car a few times before in Mexico but this was the first time at the track.
My car is a 2009 6 speed with the ECS kit + Meth Injection.
Pulled up to do a burnout before the race and the serpentine belt came off.
Pulled the car to inspect and noticed the pulley on the SC came loose.
There was no bolt/washer holding it in place.
My set up was professionally installed by a shop and it only has about 500-600 miles since i got it done.
I called ECS to get a replacement pulley, washer, bolt and serpentine belt.
Does anyone know how to get the dam pulley on SC to come off?
I tried taking it off yesterday and it doesn't just slip off.
I sprayed it with wd40 and moved it around to lubricate it.
I have a pulley puller but doesn't seem like it would work for this as there is no bolt holes on the SC that would hold the Puller bolts.
There is a keyway that is suppose to keep it aligned but since the bolt came loose it is not alined anymore.
See attached pictures. Any info would be helpful.
Has this happened to anyone here yet? Anything else I should check or replace while i'm dealing with this?
Received 1,194 Likes
St. Jude Donor '15
The bolt on mine wasn't tight, only halfway snug, when I received the head unit. Sounds like installer didn't tighten it down to me.
The pulley is a PITA to get off the first time.. there is a SC pulley puller you can buy if it's really stuck but it shouldn't be necessary. I ended up doing basically what you're doing and prying it off but it was a pain the first time. I think I used a small 3 jaw puller but it's been a while. I always think I almost screwed up the pulley when I was pulling it off, so be careful.
edit: GET A NEW KEY TOO if yours is missing.. looks like it is
Should be a key in there.
Seen it happen to others that didn't snug that up after install. Can't really tighten it until belt goes on.
I've always used a towel/pry bar to get the SC pulley off.
I did manage to slide it out about 1/2" then sprayed wd40 again and pried it out another 1/4" but it seemed like that would take hours.
I bought another pulley anyways so if I screw the one i'm removing I wouldn't mind. As long as the shaft of the SC is fine.
And I did order another key.
Thanks for clearing that up. I was wondering on how the hell i was going to torque down the bolt if the pulley spins. I didn't want to grab the pulley with vise grips. Putting on the belt then torquing it down makes sense.
I'll give it another go today after work.
Since it's partly off already, try gripping the pulley and slightly rocking it from side to side to see if it loosens. That usually works for me. Looks like your pulley got dinged pretty good too. Make sure that you either dress that nicely with something like a small triangle file or a dremel before you put the belt on (or replace the pulley) or it will probably eat up a couple of ribs on your belt.
BTW: although tightening the bolt after you've installed the pulley works fine, I have a Craftsman strap wrench, which is more or less designed for removing filters and such without damaging them, which works great for doing jobs like this. It has a handle with an adjustable rubber strap that wraps around the object you're trying to hold and grips it very tightly when you push against the handle.
I ended up renting a 3 jaw puller so I'll give that a go later.
Yes the pulley is pretty dinged up and I already have a replacement one.
I'd also get the installer to reimburse you for the work
Quick update:
Finally got it fixed. Took it to a speed shop got the pulley swapped out and had him replace the harmonic balancer since it had a wobble.
Labor wasn't so bad for both items, $400.00
I've read dealers charge about $750-$850 just to swap out the harmonic balancer.
Car was re-tuned for peace of mind and will hit the track soon.
Thanks for all the help guys.
