Car videos
#41
Nice cars guys! Thanks for sharing the videos. Gotta get me one of those hoods but worried about the paint. Silver is a bitch to match and it look like the robot who painted my car was infected with Malware
#42
Received 1,194 Likes
St. Jude Donor '15
It probably was
#45
That's just it... My car is so blotchy with uneven flake, I'm afraid the guy who paints the hood might do a good job and it won't match. Thinking about just getting inserts to get a look similar to what you and Unreal have and avoiding any paint all together. Just can't seem to find the right ones.....but didn't spend a ton of time looking
#46
Comp cam PN 54-000-11
13159R intake lobe
13163R exhaust lobe
116+3
230/246
.358/.362 lift
13159R intake lobe
13163R exhaust lobe
116+3
230/246
.358/.362 lift
#48
Yes. Idles at 800rpm, could go lower. Can lug around at 700-800rpm without issue. Makes power like I want. Does everything I asked for.
And unlike other people, I've driven a ton of different cams. Had 4 different cams in this car alone.
#49
Rained all weekend. Fixed the hose, has to test drive it. So just did 30 miles out in the rain.
#50
Took the down time to paint the pipes. Few coats of krylon. New AC Delco hose instead of cheap bando or whatever it was. Noticeable thicker and nicer.
#51
St. Jude Donor '15
That's what she said?
#52
For people worrying about vented hoods, only water that was in there was when I popped hood and it then poured down on to the radiator. Was as dry as could be, not that it matters since water doesn't hurt anything.
#53
Man, you gotta have some big cajones to drive that thing in the rain.
And that engine room literally couldn't hold another bolt in it!
#54
#55
Stock had no issues. I think it is just the material/valves on the B&Bs. Akro uses stock actuators.
Weather cleared up. Will try to get some more "fun" videos this week.
#59
Nope, 100% sure that is exactly whats on the cam card. That is cam lift, not valve lift.
