Wiring in alky control bar sensor for sd tune
How do you Wire in alky control 2.5 bar map sensor for sd tune, it's currently working great for alky set up but I'm need to go to sd tune and am not sure if I can just splice into the map sensor and wire it into the factory map wiring
Received 1,193 Likes
St. Jude Donor '15
Your question doesn't make any sense.
If you want to run an SD tune then tell the tuner to change it to SD, it has nothing to do with the alky control setup
What are you wanting to splice into? If you're running a 2 or 3 bar MAP you can use that for signaling the alky control setup if you want. But if it's already setup then there's no reason to mess with it.. just keep using the MAP that came with the kit (I'm assuming that's what you're using)
The MAF is a frequency based output, not 0-5V like the alky control needs, so unless you buy a converter then hooking it to the MAF won't work
If you have the parameters, and ecu can take them, it could work, but you want the map sensor in the manifold. The lag between the line could be enough to cause issues.
Much better to put a map on the manifold, then have the alky control signaled off that. I run a DSX 2.5 bar and then just have the Alky Control triggered off that.
Agree with Unreal. Map used for engine calculations need to be on the manifold. Too much lag connecting the map through a vacuum hose. I'd put a map on the manifold and use it for the engine and Alky, 1 less thing to go wrong
I would like to use my 3 bar GM MAP sensor to send the reference signal to my alkycontrol module. Are you saying it’s ok to splice a signal wire like that, one wire running to PCM and other one running to Alkycontrol controller and it won’t mess the signal up or cause pcm to read a different value or anything?
St. Jude Donor '15
THREAD RESURRECTION!
Correct. That’s how mine is setup. You may have to play with the little ***** inside of the control module to tweak what voltage it comes on at if it’s any different than the sensor that came with the kit. There’s a cover on the back of the controller that looks like a battery cover and there should be 2 little ***** in there you can play with
St. Jude Donor '15
yah that sounds good. This also makes me wonder if I can’t just tie into my 4psi Hobbs switch? I could just run a 5v pcm signal to the Hobbs and when 4psi it would send that 5v signal to the alkycontrol module and activate meth. Only thing I don’t know is if the MAP method is a on/off switch or if the MAP signal is what is used to correctly ramp the pump pressure/speed as you continually make more boost. Or is the alkycontrol setup just get a turn on signal at a certain MAP reference point and that starts a timed series of event with the controller that begins ramping up the pump’s pressure more and more.
Stick with using the MAP
St. Jude Donor '15
I don't remember which wire it was but just google for a wiring diagram.
The factory stock MAP sensor does not read boost, so if that is what you're running then you can't use it to control alky control.
If you're using a 2 or 3 bar MAP sensor then yes, you can use the same sensor for the engine and for the alky control system.
