Help: Best wide band 02 sensor location
I am trying to get this sensor bung installed before the header does in does anybody have any suggestions or any idea why this won't work?
Received 1,193 Likes
St. Jude Donor '15
I would put it after all the pipes have merged. Is there room to put it in the X pipe?
mine is setup similar to yours. biggest problem I had is the length of the wideband / o2 sensor and how close the header gets to the wall of the tunnel.
My PLX wideband and stock o2 sensor had just enough room. I had an 02 sensor go bad and tried to replace it with an aftermarket unit and it was taller. It wouldn't thread into the bung because it was too long.
