postion of nitrous interior switches
Would some of you guys with 06 vettes be kind enough to post some pics. of where and how you installed your wide open switch and where you put your activation button for your nitrous. I've got some idea's but want to see the most finished looking way of installing it..........appreciate the help. Thanks.
For the wide open throttle switch I just went with a NOS mini progressive controller. That along with any window switch will work just fine. I didn't want to run on or the little micro switches. As for the arming switch I bought a full panel from eBay. Apparently a guy makes them for C6's and can build it any style to your liking. It hides inside the factory ashtray
I used an NX tps switch because I'm not a fan of microswitches. I had bought it about 4 or 5 years ago, it was still in the box. I drilled a small hole in the adj. Suspension panel on the console to mount my switch that arms the whole system. I'll be moving to a lower profile switch in the near future.
