boosted e85 afr opinions
trying to set up my initial PE tune for e85. Is commanding .80 lambda (7.82 afr ) a good starting point at 14lbs max boost? Cant find enough information that I would validate as good info.
I don't plan on changing my meth setup.
I run 1.27-1.275 on my flex fuel setup. Was at 1.278 prior to dialing in the tune saturday and settled on 1.275 and let the meth do the rest.
Then again this was 24+psi of boost on e60-62.
I usually start around .78 and tune from there
Received 1,193 Likes
St. Jude Donor '15
0.90 lambda should do nicely
Just kidding
Been doing more like 0.82 lambda on mine
Just kidding
