fuel rail test port core removal
Is it nesasary to buy a core removing tool ? Can it be removed by any other method ? Last step in my install of nitrous. If I do need one, where can it be purchased ? Thanks....Oh, forgot it's a 06 LS2
Same tool that removes the valve from a valve stem in a tire. Should be able to get it at an autoparts store.
The rail could be under pressure so be careful when remove it. If you depress the tool into the core it will relieve. You may want to have a small towel beneath it to catch any fuel that's in the rail when you remove it.
