LS7 - Boost Build
LS7 - Boost Build
Need some advice on what I'm missing goal is about 650-700 rwhp, I want to make sure the short block is solid, only want to do this once.
- original block
- darton dry sleeves pressed in
- callies compstar h beams
- callies compstar crank
- weisco pistons with steel wristpins
do I need to worry about the new rotating assembly being heavier, piston slap, what am I missing?
- original block
Received 1,194 Likes
St. Jude Donor '15
Have heard of a few people breaking compstar cranks. I'd about consider a stock GM one before one of those
Really at 650-700rwhp range? I mean 1000hp+ I could see but my stock crank would need to be rebalanced and worked over, plus the rod bearing failure ate into it a bit.
I just did drop in CP pistons (10:1) on my LS7 and had the rotating assembly balanced with stock crank/rods. I'm sitting at 750 whp on 91 + meth. If 650-700 is your goal, you should be fine with what you have planned and it may be a little excessive, if you don't plan to push it harder.
St. Jude Donor '15
Personally I would pay extra for a better crank/rods. Small difference now to never worry.
Need to decide on ring pack. Builder should be able to guide that.
Of course you have to worry about balancer/slap/clearances. Not sure what you are asking there.
ARP mains or stock? Would need to get the motor machined with the appropriate hardware.
Now the question is really do I need to change the heads I had that were ported, new guides, dual springs, and stainless exhaust valves put in..
Darton sleeves will take 1000+ with ease.
