Need help tuning TCC for A6 shift points
I changed my A6 shift points with HPtuners. Now S mode will hold gears longer and downshift sooner (S mode is EXACTLY the same as D mode from the factory). My question is, where do I program the TCC apply/release settings? Is there a rule of thumb to get close? HPtuners forum hasn't been much help for the A6. Some suggest setting the TCC to lock 2mph after a shift. But the stock tune has tables where the TCC is actually applied BEFORE a shift in higher gears.
Thanks Tracy, I'll do that. BTW, I decided to try turning the Master TM switches off but the downshifts were just too abrupt for life here in the cold north. The car already gets squirrely on downshifts, no need to make traction an ON/OFF situation. BUT, for kicks, I turned just the Upshift TM off, and WOW, what a difference! I can't wait to get back to the track to try those shifts out. I just hope I don't break anything using DR's.
what do you mean by unlocking the tables? Is there still no way to completely disable the TM on the A6? I am very new to this but my understanding was that with the predator tuner you could lesson the effect but with more complete tuners (those able to access the a6 controll module such as hptuner) TM could be completely disabled.....what is the full story?
that sux....does any tuner offer this ability? What about custom tunes such as chuck coW etc?
siffert you are making it a habit of answering all of my questions.....thanks!!!!
I have an HP tuner. Since I plan on only using my drag tires at the strip and to and fro, I dont see the need to adjust the tire diameter in HP Tuner, like you mentioned elsewhere. Why should one? I know it has no effect on your ET/MPH. Though I would guess you scanned logs of the "speed in mph" info would off by 4.5% or so along with your shift points.
Once again you have the answer.....I read that shift points are controlled by mph instead of rpm so that someone running a shorter than stock wheel/tire combo could possibly hit the rev limiter before reaching the stock programmed shift mph. I also read where ABS/TCS/AH can be thrown a loop by different-than-stock tire diameter. While I won't be using TCS/AH I will be relying on the brakes and I would like them functioning properly.
Also, I personally recommend only shutting TC off, not AH. AH has nothing to do with straight line performance or TM and could save your skin on the strip. In the C6, the TS-Off setting gives you the aggressive form of Active Handling (AH), a crucial tool in the event the rear gets loose with those hot Hoosiers of yours. In contrast, Competitive Driving mode relaxes AH. That’s undesirable unless the car’s on a road-race course or auto-X.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Yes, I can do it.......
I'm not using HPT to do it....
Most people mistakingly think that it is a button you push....Like anything in life....It's much more than it appears on the surface. This vehicle is a comprehensive "SYSTEM" and pushing a button or flipping a switch not gonna do it....
The engine and trans must be programmed as a "SYSTEM" to get quality results.
I have done more A6 cars than anyone out there...I can help you.
Additionally, I can custom tailor the shift feel to your liking.
Call me any time and I'll explain.
Chuck CoW
Yes, I can do it....It must be done in person. I only wish I could do it through the mail.
Chuck CoW
Chuck CoW
I think every C6 A6 1/4 mile drag racer on these forums would be very interested in anybody being able to completely eliminate TM from an A4/A6 1/4 mile WOT run, including eliminating TM at launch. I and many others have data logged many times with trying different programming but TM is always there at launch with timing advance going negative at launch.
I know so far it has not been done, but am quite open for anybody to prove to us wrong, of course with empirical data showing no loss of timing at launch.
Does anyone know of any threads with data of just a tune and DR's consistantly hitting sub 1.9s? I've only heard rumors.
No disrespect for Chuck, but when you tune as many as he has, you'd expect to see real data before long. Where are all the sub 1.9 60's from just a tune? You'd expect people who pay for custom tunes to be at the track more often.
I am not sure you'll find what your looking for. Most with DR's are serious enough to have headers, cai's etc. I'd just like to see some before and after tune 1/4 mile times. I know I picked up .15 from TM upshifts disabled and another .12 from additional tuning off my installed headers.
