Adding mods w/ no tune... watching A/F on dyno, but curious about timing advance
I've added a Halltech intake and ported stock intake manifold to my LS3 and plan to add C6Z manifolds/cats/3" x-pipe to my stock mufflers.
It's easy to see the change in A/F on the dyno as I add the mods, but I can't tell what's happening w/ the timing. Is there anything I need to worry about? I'd assume the stock timing is low enough that I wouldn't need to turn it down lower w/ mods, but just wanted to check.
As far as the reason for no tune, the car only has 900 miles on it and I'd like to get through a few thousand more miles and maybe year of ownership before I tune it incase a manufacture defect appears that could be blamed on a tune.
The MAF sensor could detect a change in air flow and the ECM can compensate for that change. In a lean condition, the ECM could add fuel to compensate back to the factory setting. Therefore, I was just curious to what the A/F was at either cruise or WOT?
Here's the dyno stock vs. w/ the mods showing the A/F
Unless there's something I'm missing, I'm pretty comfortable w/ the A/F.. more just curious about the timing advance since I can't see that or timing pull w/o a scan tool.
Do you mean the MAF sensor can detect a change in air flow and the ECM can adjust timing advance as well?
And the stock timing map is conservative enough that I'll never have too much timing advance as long as the A/F is in check will I?
I guess what prompted this was someone saying they had to take a degree or two out when they added a ported intake manifold... just wondering if I need to pay attention to timing in addition to A/F, or if I can just watch the A/F and assume that the stock timing is ok for the car.
A bolt on part could be removed if need be w/o having a gap in the recorded vehicle history like swapping an ECU would have. I also feel it would be less likely for my dealership to argue about an intake and ported stock intake than a tune. Seems the tune warranty voiding comes from higher up and can't really be looked over.
