Swapping ECM's in an '09 base
If I take out my stock '09 ECM w/ 2,900 miles and put in a new blank ECM and have it VIN matched/tuned/ect. and run it for a few thousand miles and switch back to the stock ECM, do I need to do anything different at that point besides just plug and unplug the two? There are no calibrations that need to be done when swapping back and forth and no error codes or weird issues that will pop up?
I'd like to clean up my a/f tune so that the car has better driveability w/ my mods, but I'd like to use the stock ECU when running the car hard to keep it conservative.
I just want to make sure after the initial calibration of the new ECU I can swap back and forth w/o needing any calibration and that it doesn't brand the ECU with a time/date/mileage stamp when it's removed and reinstalled.
"Clutch Pedal Position Learn" bit me trying to do that very thing on my 2009 MN6. Wanna buy a slightly handled but never fired up ECU?...
Oh and no "clutch pedal position learn" means no start FYI. HP tuners has a button for this function but it never worked for me.
The "clutch pedal position learn" has to be accomplished with the ECU installed in the car. From what I've been told the sensor changed from a simple off/on function to some sort of linear/rheostat switch in 2009. I suspect, but don't know for sure that HP tuners has that function working in pre-2009 cars and assumed it would be the same in 2009 and up. For me, it was a no-go and I've never found the HP Tuners folks to be that responsive to customer queries so I just...gave up and put it on the shelf.
If you get your ECU programmed at the stealership and get them to start your car with it you'll be good to go I would think.
Ok, that sounds like it will work then...
I have a 100% stock ECU in my car now that came with the car when I bought it new.
I'm buying a 2nd ECU and having my tuner use their Tech II to match it to my car and tune it. (sounds like this should take care of the issue you had)
Now I'll have 2 ECU's that can be swapped in and out of the car at will w/o any calibration or relearning/reprograming needed. The 100% stock, original ECU that came with the car.. then the tuned ECU I bought separate.
Does that sound right?
I did the 2 ECU thing with my 09, put the OEM ECU on a shelf in the garage with the intent of switching it out if needed, well G.M. located the unit at the highest point in the right front fender, much higher than in prior years, so high that it is almost impossiable to change, I went to a very well respected Corvette shop to try to have them switch the two units, they said the only way to get at it is to remove the fender. When I sold the car instead of switching out the ECu's I just reflashed the 2nd ECU with my EFI Live to save the crazy hard job. Now I have the OEM ECU that came with the car. Anyone need or want to buy it?
As long as you are not a dwarf you should be able to reach it. I think I used a 1/4" drive rachet with a 10mm socket...2 bolts. Once it's loose they ECU will swing around on the connectors/wire bundles allowing you to lower it to about bottom of the car height to unplug the two connectors. 5 minute job if the right front corner of the car is jacked up.
