Predator 7194 Failure?
I just was in the process of installing the Diablo tune in my '08 C6 A6 for the first time and the unit just died or shutdown at the final steps of install. It appears it got to the point where it's supposed to confirm that I selected the Diablo tune, it's step 16 in the booklet, like the last step and that confirmation screen flashed for about 1/2 a second and then it went dead; just shutdown.
So then I tried unplugging the unit, turned the ignition back off, and plugged the unit back in again, like starting from step one, but now the unit does nothing. Wont boot up/start up, nothing. I was a little nervous, but started the car and no issues, so far. Drove it down the block and back and didn't really notice any diffrence.
So now I'm not sure what to think or do. Any one have an idea or three?
p.s. This is my 2nd Predator; I have one for my GTO, so I'm familiar with the process and I've never experienced anything like this before with my other unit.
Supporting Vendor
yeah, check your cig lighter and aux power fuses... if those blow, your obd port has no power either...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Please post some feedback when you get loaded and going. I have an JSB 08 A6 and looking at a predator set-up. I hope to improve the way the transmission acts and would like to here how it does in that area and a little more power is a good thing have. I also like the fact you can reload the stock tune if there is a warranty problem or move it into a GS or ZO6 down the road. GL with the install.
Supporting Vendor
you can also plug it in to another vehicle's obd port to see if it powers up... that'll tell ya if it's the predator or your car having the issue...
have the power adapter for it? can plug that into it also and see if it powers up...
On another note, the tune definetely took. I drove the car for about an hour yesterday and it was very apparent and the car performed very well, even the shifts are better.
But I don't know what to do now about the dead Predator.
Monte: any more suggestions? Thanks
Supporting Vendor
So, here's the latest. I checked the fuses, both the Lighter and the Accessory, both are good. I tried plugging the unit into the port again and then turned on the ignition, nothing. I've got the power adapter so I tried that and the screen lit up but stayed completely blank.
if not, then it sounds like the screen may have crapped out, so you should call diablo tech support on Monday...
on the back of the predator, you'll see a recessed screw... try turning that while the unit is powered up - that screw is for the screen contrast, and hopefully should bring things back into view...
I'm very happy overall (save for the dead Predator now that I've still have to go through tech support on Monday to trouble shoot, hope that goes well), with how the unit performed.
It definetely "wakes" up the car, shifts are quick and crisp now, car has a very noticeable increase in power too. It pulls much harder from mid-upper RPM range and better throttle response from the jump. Guessing that a took a few tenths off my 0-60 times too.
For $275 shipped, this has to be one of the cheapest HP gains you'll find anywhere!
Oh, I almost forgot about the increase in freeway MPG. I travel 41 miles one way to work and it's 95% freeway. I reset the avg. MPG indicator. I was getting a solid 25-26 MPG using cruise prior to installing the Predator tune. I couldn't believe it when it now averages 30.5 MPG at 72mph I checked it twice and came up with the same result, amazing
To me, it's worth every penny! I just hope tech support takes care of me.
Thank you for the update. Also glad to here the tune loaded and you had no running problems.Please let us now how your dealings with tech support work out. That was a great price for the unit! Best I can find is 300 and fifty more for the PC cable. This was a new unit correct? Could need some of that info also.. Nice improvement on MPG! I did 27.5 mpg on a vegas trip last may. You tell people and they look at you like you are crazy These cars are awsome all around and have killer style.. Wife is good with it so just need to find the deal and pull the trigger. Thanks again! Ill keep checking to see how it goes.
Supporting Vendor
if there is a screen issue, no big deal, the tool is under warranty for 2 full years.
fill out the rma request form on our website and we'll get it fixed up asap.
Mike does the tuner adjust anything in the trans? The A6 in the 2010/11 has different programing from early years from what I have read. I know it's been asked a zillion times but on a "2010" LS3 what kind of performance and mileage improvement can one expect.
Supporting Vendor
No, trans support is limited to improved shifting through the torque management changes in the tune.
Trinity will be getting updates to add support for the TCM in the near future.
From what Monte posted and from what I can tell, that seems to be the issue and I hope nothing more. I'll fill out the RMA request form as soon as I get home from work; assuming I need my Predator specifics, i.e. serial number, etc. Thanks for the reply.
I just spoke with Mike and will be getting my RMA squared away today . I hope it goes smoothly and doesn't take too long...I still have to modify the Predator tune that I was able to load just before the unit died
The Unit has been returned to DiabloSport, fingers crossed it goes well and quickly!! I'll post up after I know the end result when I get the unit back.
