C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Anyone successfully used Gopoint Technologies' GL1 OBD-II iPhone/iPad Interface?
Old 06-13-2011, 01:57 PM
pwo
Red Scorpion
Support Corvetteforum!
pwo's Avatar
CI-VIII Veteran
Default Anyone successfully used Gopoint Technologies' GL1 OBD-II iPhone/iPad Interface?
Just got my Gopoint Technologies' GL1 OBD-II iPhone/iPad Interface and tried to use it on my 2003 C5 and my 2007 C6 Z06.
On both cars I get the same BBD-II Error: OBD-II interface not found.
The iPhone does get charged, and I did reset my iPhone as described in the Quick Start Guide.
Has anyone successfully used a GL1 on a Corvette?
Cheers
--pwo
Old 06-14-2011, 06:49 PM
ZBADESTZ@Straightline
ZBADESTZ@Straightline's Avatar
I have one. I have mine hooked up to my ipad. I had same issue. I called gopoint and they walk me thru it to work.
There just a setting you need to do
Hope this helps
Old 06-15-2011, 02:56 AM
pwo
Red Scorpion
pwo's Avatar
CI-VIII Veteran
Cool, do you happen to remember which setting had to be changed?
Cheers
--pwo
Old 06-16-2011, 04:13 PM
pwo
Red Scorpion
pwo's Avatar
CI-VIII Veteran
Make sure you select the correct interface .....
then it just works ...
Cheers
--pwo
To Anyone successfully used Gopoint Technologies' GL1 OBD-II iPhone/iPad Interface?
Quick Reply: Anyone successfully used Gopoint Technologies' GL1 OBD-II iPhone/iPad Interface?
