How do you tune for 72lb injectors? Do you put 36 lb injectors and double the voltage?
Thanks,
Derrick
Do you have injector data supplied from the manufacturer? They should be able to supply you with IFR tables and the other necessary data....if not, run. Before you even get into scaling if you are beyond your 63.5lb/hr limit you need the correct data
