Best priced Camaro Corvette Tuner in Florida Tampa Tuning
St. Jude Donor '12-'13-'14
Best priced Corvette Camaro Tuner in Florida Tampa Tuning
Tampa Tuning is the new sponsor
Best priced Corvette and Camaro Tuner in Florida. www.TampaTuning.com
For those that don’t know me, Phil'sC5Vette, Ive been tuning LS series cars since 2002-2003. I’ve cruised with many of you and had breakfast, lunch and Dinners with many of you. I sponsor the south Tampa Hooters night near the Gandy bridge the 2nd Wednesday of each month to hang out have a drink and a wing, and talk with your peers on car modification.
I also attended the basic and the advanced tuning schools which trains you how to tune with HPTuners. I return often to the schools to allow the students to work on my car and see what new cutting edge information is getting out.
In the beginning, I corrected dozens of local tunes for free and this opened the doors for more and more referrals. The last couple years, my business has been word on mouth. I signed on to a couple more Corvette and Camaro forums, and I heard firsthand how unresponsive tuners were with follow up and customer service.
Ill spend about 3-4 hours on your car making it right. I dive in deep, and stay with you till the car is how you want it.
Just reach out for us if you're not happy with your current tune or service. Ill review it and take a look for you for free. I’ll give you my honest opinion and the wideband doesn’t lie.
www.TampaTuning.com
813-727-8720
Best priced Corvette and Camaro Tuner in Florida. Tampa Tuning
www.TampaTuning.com
813-727-8720
JOE Gifford (07-22-2017)
Best priced tuner in Tampa
3 miles away from MacDill AFB in Tampa.
Please reach out for Tampa Tuning for your best priced tuning !
Our total street performance tuning package for $280.00 will include:
- Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
- Increase power enrichment rate mode
- Examine and change timing tables for additional horsepower & torque gain
- Optimize your vehicles Air and Fuel Ratio monitored by the LM-1 wideband unit
- Reduction of intake air temperature table (heat soak)
- Desired rev limiter adjustments
- Park, neutral, and in- gear idle adjustments with and without A/C active
- Adjust power enrichment delay to immediate (*Transmission Performance*)
- Engine torque management system reduced (*Transmission Performance*)
- Transmission torque management system reduced (*Transmission Performance*)
- Transmission shift points enhanced (*Transmission Performance*)
- Transmission shift times reduced (*Transmission Performance*)
- Transmission shift pressure firmness enhanced (*Transmission Performance*)
- Skip shift deleted (CAGs 1st to 4th shift) (*Transmission Performance*)
- Fuel injector rescaling for aftermarket injectors
- Cooling fan activation temperature recalculated
- Perform speedometer recalibration for rear gear ratio and tire size change
- Turn off check engine light and remove trouble codes
- Neutralize rear oxygen sensors
Transmission performance package for $160.00
Tampa Tuning recognizes that the A4 and A6 automatic transmission owners just want their sloppy, slow shifting and sluggish transmissions tuned for a performance feel. For those owners, we designed a transmission only tuning package. We will reduce your vehicles engine and transmission torque management system and re-flash only transmission settings indicated above by *Transmission performance* notation. This will be a very noticeable change in your vehicles performance!
Torque management reduction tune for $75.00
For the drivers that just want a noticeable change in your vehicles performance, and are tired of the 1st to 4th CAGs skip shift, Tampa Tuning will reduce your vehicle’s engine and transmission torque management system and neutralize your CAGs. You will be surprised and pleased with the torque management tune. Many drivers who use their vehicle daily say just turning off the CAGs are worth the price and the extra seat of the pants torque is a bonus.
Email order tunes for $130.00
If you own or have access to HP Tuners software, you can Email your stock .BIN file to Tampa Tuning where it will be reviewed and properly enhanced for a “Email order” tune. Your tune will be enhanced by using HP Tuner tables from our library of modified configurations which have a very similar set up as your make and model vehicle.
www.TAMPATUNING.com
813-727-8720
www.TAMPATUNING.com
813-727-8720
