C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
90mm TB v. 102mm TB on FAST 102 comparo.
Old 02-08-2012, 02:50 PM
0Mike @ CMS
Former Vendor
Mike @ CMS's Avatar
Default 90mm TB v. 102mm TB on FAST 102 comparo.
So we have all seen good numbers made with the FAST 102 intake manifold and 102mm throttle bodies, we wanted to see just what kind of difference there is between a stock 90mm and a 102mm. Our friend Chris was nice enough to be our test subject. He brought by his 2005 Pontiac GTO A4.
4.125" bore x 4" stroke 427ci
West Coast Cylinder Heads Stage 2 LS3 heads
Ported Fast 102 w/ stock 90mm throttle body
Comp Cam 235/243 114+3
1 7/8 Headers w/ custom dual 3" magnaflow exhaust
Prototype Over the radiator intake
Tuned by Ryne with HPTuners in speed density
Xtreme Transmission built 4L65 w/ 3600 stall converter
Converter was locked during dyno pulls.
Pink= stock 90mm throttle body
Green= 102mm w/ Prototype over the radiator intake
Red=102mm throttle body w/ Halltech M107R Air intake (corvette intake)
Red :We picked up 11whp and 20wtq from a simple throttle body swap and Halltech M107R air intake, being that this car is tuned in Speed density, the additional air flow is clearly recognized by the leaner A/F ratio. Obviously the Halltech does not fit on the GTO we installed it simply for comparison.
Old 02-09-2012, 08:39 AM
C7&7
C7&7's Avatar
very cool.
Old 02-09-2012, 05:37 PM
0Cunningham Motorsports
Former Vendor
Cunningham Motorsports's Avatar
we thought this could be a informative post for people who are thinking about spending the coin on a NW102 and a halltech M107r or Cf112 intake...... obviously this is a ls3 headed motor, and obviously on a ls7 motor with the gains will be more...
Old 02-09-2012, 06:09 PM
ITS STOCK
ITS STOCK's Avatar
Wow it picked up some nice gains in the mid range too. I wonder if I could see 10whp gains on my smaller cubed motor.
Old 02-09-2012, 09:22 PM
TurboLX
TurboLX's Avatar
So that's a 2.2% improvement at best, part of which is admittedly due to a change in AFR. I'd be curious to see what's left once AFR is adjusted equal for all cases. Most aftermarket dynos are rarely accurate to less than 2% and combustion stability is at least 1% error anyway, so I'm not completely convinced.
Interesting experiment, but I'm not sure it justifies the cost and potential reduction in idle/tip-in control.
Old 02-10-2012, 09:56 AM
Former Vendor
yeah greg i didnt even touch the tune, just swapped and ran it.... for what it is worth, i have tuned this particular car to death, have had the AF all over the place, and it has always made same power at 12.5 as it did near 13, so for what its worth, that might help a little, i probably should have corrected the AF, but it was a quick test and i ran out of time , had a customer showing up for a tune.... the fact that it did go lean with the addition of the Halltech intake does indicate the airflow increase, therefore i feel the potential is there in a higher airflow motor like an ls7
Old 02-11-2012, 11:39 AM
locosmith
Support Corvetteforum!
locosmith's Avatar
Not worth the bread...Pfft
Old 02-11-2012, 03:33 PM
firefighter813x
firefighter813x's Avatar
Changing the intakes skews the numbers... did the first dyno pull have the same intake as the second?
A test on a stock cubed LS2/LS3 would be more interesting. I'm sure that any restriction in airflow on a large engine will inhibit dyno numbers. As locksmith mentioned, the cost for those few horsepower isn't worth it IMHO.
Regardless, thanks for taking the time to post results and do tests like these for the forum.
Old 02-12-2012, 11:54 AM
Former Vendor
the second run was with the same intake as car runs everyday
Old 02-12-2012, 12:18 PM
HoustonSVT
HoustonSVT's Avatar
Seems to me to make it a true comparison you would now need to put the 90 tb back on and leave the Halltech 107 cai on, then compare that.
Old 02-12-2012, 12:34 PM
KLLRVET
KLLRVET's Avatar
was this the same intake used on the 90mm test and the first 102mm test?
Old 02-12-2012, 01:32 PM
Former Vendor
yes.... the first run is with the existing 90mm tb and intake, the second run is with the addtion of only the 102 tb, the third on was with the addition of the halltech intake
Old 02-12-2012, 06:03 PM
_GTO_
_GTO_'s Avatar
Impressive gain
Any pics with the M107R installed on the GTO ?
Old 02-19-2012, 01:17 AM
BLW BY
BLW BY's Avatar
JML
You should run yours on their dyno, they've got big #'s
Old 02-19-2012, 01:32 AM
BLW BY
BLW BY's Avatar
Originally Posted by BLW BY
JML
Those HP# would be 630+ at the crank.
Not realistic!
Please; Inform the public.
Old 02-19-2012, 01:26 PM
Former Vendor
Not realistic!
what are you talking about? 511 rwhp equates to roughly 580-590 crank, remember the converter is locked during these pulls....
Old 02-19-2012, 01:27 PM
Former Vendor
Originally Posted by _GTO_
Impressive gain
no, it didnt fit at all, not even remotely close, only good for a dyno comparison
To 90mm TB v. 102mm TB on FAST 102 comparo.
Old 02-19-2012, 03:54 PM
90droptopp
90droptopp's Avatar
Location: Murrieta Ca..... America, fun while it lasted
JML
I own the GTO in question. Are you saying my numbers are inflated?
Old 11-17-2012, 07:44 AM
Justasheet
Justasheet's Avatar
I ran the same time as you in humid South Florida and I'm only @ 479hp to the wheel. Does seem a little high (511 hp) but I'm not questioning your word.
Jeff
Old 11-20-2012, 09:05 AM
JUIC3D
JUIC3D's Avatar
St. Jude Donor '11-'12-'13-'14
GTO only weighs what, 500lbs more than a C6?
Quick Reply: 90mm TB v. 102mm TB on FAST 102 comparo.
