C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
LS Valve Spring Kit SALE
Old 02-27-2012, 02:32 PM
COSPEED
COSPEED's Avatar
St. Jude Donor '10
Default LS Valve Spring Kit SALE
Lunati LS Dual Valve Spring Kits
The LS Dual Valve Spring Kits come complete with dual valve springs, retainers, spring locators, locks and valve seals that are ready for drop-in installation on many popular LS applications. Using a Signature Series Valve Spring, Lunati engineers have developed new wear-favorable, lightweight alloy steel retainers and locators. These designs prevent* chafing in the spring pockets of aluminum heads, making the combination unbeatable for both serious performance street and drag racing. Other features include:
• Locks equipped with inner bead locks; 7° interference angle between locks and retainers causes the locks to clamp valve stems more tightly
• Valve seals are made from Viton synthetic rubber and are steel jacketed to guarantee seals remain tight around guides and are protected from springs
• Viton material is ideal for resisting heat and aggressive racing oil additives that cause swelling and distortion
CURRENT DISCOUNT COUPON CODES
If you have any questions, please e-mail or call us as we do not frequent CORVETTE FORUM and may not answer any posts in a timely manner. Thank you.
COSPEED
COSPEED's Avatar
St. Jude Donor '10
COMP Cams LS Engine Valve Spring Kits
• Kits designed for hydraulic roller cams that include carefully matched Beehive™ Springs, retainers, locks, seals and spring seats
• Kits available with steel, lightweight Tool Steel or titanium retainers
• .600" maximum lift for kits including part #26915 valve springs
• .625" maximum lift for kits including part #26918 valve springs
• Dual spring kits designed for hydraulic roller and some solid roller cams
• Include matched valve springs, retainers, locks, seals and spring seats
• Kits available with lightweight Tool Steel or titanium retainers
• .650" maximum lift for kits including the part #26925 valve spring
• .675" maximum lift for kits including the part #26926 valve spring
Old 07-24-2012, 04:29 PM
COSPEED
COSPEED's Avatar
St. Jude Donor '10
BT Racing LS Dual Valve Spring Kits
Brian Tooley, formerly of TEA, has come out with several dual valve spring kits for LS cylinder heads. With years of experience in LS cylinder head design, Brian now offers the ultimate dual valve spring kits for LS cylinder heads.
The LS Platinum Dual Valve Spring Kit features Polished inner and outer springs, matching titanium retainers, locators, seals and locks. On completely stock heads the springs setup at 160 lbs @ 1.770” installed height, 380 lbs @ .600” lift and 400 lbs @ .650” lift and coil bind at 1.070"
This dual valve spring kit is designed for use with stock rocker arms. Open pressure in endurance applications should be limited to 400 lbs or the valve tips can be damaged. This kit uses OEM locks, stock locks allow valve stem rotation which helps the durability of the valve tips.
The LS Max Pressure Dual Valve Spring Kit is designed for heavier roller rockers. They check at 160 lbs @ 1.800”, 420 lbs @ .600” lift and 450 lbs @ .650” lift and coil bind at 1.100". These dual valve spring kits feature excellent durability in maintaining spring pressure.
This dual valve spring kit is designed for use with roller rocker arms, or track only combinations using stock rocker arms. This kit uses OEM locks, stock locks allow valve stem rotation which helps the durability of the valve tips.
Old 09-18-2012, 03:38 PM
staticki
staticki's Avatar
I have an england green mayhem2 cam and running patriot gold dual springs. I am tired of my car sounding like a typewritter.
What would you suggest swapping out to that are the same strength, but wont get the same valvetrain noise?
Old 10-22-2014, 01:53 PM
COSPEED
COSPEED's Avatar
St. Jude Donor '10
Manley NexTek Valve Springs
Manley valve springs are wound from super clean alloy. Each design minimizes stress to ensure long service life with high lift camshafts. Retainers are manufactured in our own double spindle CNC machines to exacting tolerances and precise installed height specifications. Locators are manufactured in our own CNC lathes. Heat treated and black oxided after machining. Valve locks are manufactured in our own Swiss turning centers with rigid control over the all-important angle to ensure precise mating with the retainer.
To LS Valve Spring Kit SALE
Quick Reply: LS Valve Spring Kit SALE
