[Wideband question] Dyno tailpipe wideband vs X-pipe NGK AFX - which would you trust?
St. Jude Donor '11-'12-'13-'14
In the battle to legitimately make 500whp cam-only, I added a ported intake manifold and took a trip back to the dyno to make 3 pulls.
No change in tune, the car lost 10wtq and gained 6whp, but the air fuels were quite different in the midband.
I logged all 3 passes and the NGK AFX showed a/fs as low as 11.3-11.5, a far cry from the nice and steady 12.5-12.8 the car maintained with the stock manifold.
How much variance can one expect when comparing widebands?
I would expect the tailpipe wideband to read more lean as well, and it looks like it's about a half point difference than the NGK.
You must remember that calibrating the NGK piece is pretty important too. I would think a freshly/properly calibrated tailpipe sensor would be good as well.
No, I would not really put a lot of faith in a tailpipe sensor. Even calibrated, they are subject to fresh air wash at the tailpipe location. The cats can actually skew the reading *either* direction, depending on what the engine was doing previously. Catalytic convertors act like a "sponge" for oxygen and work both ways.
Ideally, you just want one good quality, calibrated sensor upstream of the catalyst with a controller that does proper sensor temp control and correction. Hopefully, your exhaust backpressure won't be so high as to skew the reading from pressure, but that's usually not an issue with most high performance exhausts.
Thanks Greg, I appreciate you chiming in. I just bought the Advanced tuning book from Barnes and Noble and am slowly making my way from page 1 to the end.
St. Jude Donor '08
negative on the tailpipe sensor
Just switched my Innovate LM1 sensor from my Innovate tailpipe sensor bracket to my header bung and went from AFR's in the 19's to 13's! This is with a high overlap cam but I will not trust tailpipe adapters in the future. LM1 sensors are not the best but as you can see, tuning under these conditions are impossible.
^ That sounds about right.
I just made 517whp/462 torque cam-only with timing at 24* and fueling in the 12.4-12.6 range. That was off my NGK sensor--the dyno showed much closer to 12.7-12.99
Yes, it's always a good idea to verify the sensor calibration prior to working on a car.
Just curious though, wouldnt that mean the LSx tuner shops would need to install the wide band upfront with a bung on each of the cars they tune to get an accurate reading? Im only asking because I notice 95% of the shops ive seen use the wide band attached to the tail pipe. Or can the sensor out back be calibrated for the location?
Platinum Supporting Vendor
Hi,
If I am calibrating a car that does not have a bung I remove sensor 1 and install my WB, then I remove sensor 2 from behind the cat and install sensor 1 and shut down the codes for sensor 2. I am only calibrating in open loop so I really do not care what my sensor 1 is reporting, but it needs to be there. My WB has a accuracy of +/- 1.5 % vs the factory of like 8-10%, so I want my WB data to be the most accurate that it can be. If you "tuner" has the ability it is always nicer to install a dedicated bung for the WB.
