Adjusting shift mph/rpm A6 with HP tuners or INTUNE
Hey guys,
I have an ECS trans tune in EFI Live format that was saved by my local tuner using HP Tuners when it was dyno tuned after installing ported fast.
Can HP tuner or Diablo Intune be used just for the purpose of adjusting the shift points eventhough the TCM was originally tuned with EFI Live & an autocal? I like everything about the EFI live tcm tune that Doug at ECS did, but I do hit the rev limiter occaisionally at the track on the 1-2, 2-3 shifts which I need to stop. Not a fan of the Autocal for tuning purposes so looking for other options. Thanks!!
Hey guys,
Ed M
Supporting Vendor
Hey guys,
Supporting Vendor
We have worked extensively with ECS, and a few other respected GM tuning shops to make sure our TCM templates contain the stuff you need to properly tune most of these TCMs. The inTune is a proven piece of hardware that will allow the user to do what he is asking, without having to understand how the TCM works, which should be a prerequisite for anyone planning to tune their TCM themselves.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
I dont know about "way more features"? There are one or two tables available in the std versions of HP, but there are other tables in EFI that HP doesn't have so that can go either way really. If your in deep enough with either software company, you end up with all the tables in both...
Diablo has been a pleasure to work with thus far and we are working on a promo sale coming soon on In Tunes with an ECS tune file. PM if interested.
Last I heard, EFI still didn't have the shift torque factor adder. That's a big one for me.
Is iTune capable of this change?
I can only shift to 4th above 19-20 mph in paddle. Is there a way in HPT that I can change my file so that my 3-4 will shift at a lower speed perhaps 15 mph? It's not a problem, probably more out of curosity. The 2-3 will paddle about 5 mph then a pretty long way until I can shift to 4th.
You will only cause engine damage by lugging the motor badly.
It is an auto, you can't lug it. They have minimum speeds for converter lock up.
I just really want to know if the adjustments can be made that I outlined above.
I agree, both are close, especially with the latest EFILive release giving you more access to the Pattern B parameters. GM themselves made it easier with less shift time tables in 2010 1/2 and up
What I like about HPTuners is the Inertia Factor Profile tables for quick specific tweaking of shift firmness and the Shift Torque Factor for tweaking specific torque management area's without having to disable Torque Management entirely. But as you said, you can tune with both and there is always more than one way to "skin the cat" as they say.
Have a great weekend
Ed M
