Scan comes up with error codes, could use help
Hi,
Recently (fri)my gf bought an 09 Corvette base with auto transmission.
Today got my hands on an obd2 scanner and got some error codes!
If someone could please explain them to me or suggest a fix! no engine light yet but still want to know, also idle is a bit rough!
Mode $06 report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0.49886V Min: 0.49886V
Test result value: 0.49886V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.30012V Min: 0.30012V
Test result value: 0.30012V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.60036V Min: 0.60036V
Test result value: 0.60036V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 189ms Min: 0ms
Test result value: 24ms
PASS
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 212ms Min: 0ms
Test result value: 13ms
PASS
MID:$01 TID:$80
Max: 65,535Changes Min: 30Changes
Test result value: 211Changes
PASS
MID:$01 TID:$81
PASS
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 590Count Min: 0Count
Test result value: 94Count
PASS
MID:$02 TID:$8b
Max: 2.04936V Min: 0.80544V
Test result value: 0.81923V
PASS
MID:$02 TID:$8c
Max: 0.14994V Min: 0V
Test result value: 0.03941V
PASS
MID:$05 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
Max: 0.40016V Min: 0.40016V
Test result value: 0.40016V
PASS
MID:$05 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 2 Sensor 1
Max: 189ms Min: 0ms
Test result value: 34ms
PASS
MID:$05 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 2 Sensor 1
Max: 212ms Min: 0ms
Test result value: 18ms
PASS
MID:$05 TID:$80
Test result value: 113Changes
PASS
MID:$05 TID:$81
Test result value: 112Changes
PASS
MID:$06 TID:$8a
- O2 Bank 2 Sensor 2
Test result value: 96Count
PASS
MID:$06 TID:$8b
PASS
MID:$06 TID:$8c
Test result value: 0.03697V
PASS
MID:$10 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 4 Sensor 4
Max: 45,063 Min: 22,546
Test result value: 65,520
FAIL
MID:$21 TID:$07
Minimum sensor Voltage for test cycle(calculated) - Catalyst Monitor Bank 1
Max: 41,113mHz Min: 4,144mHz
Test result value: 1,824mHz
FAIL
MID:$21 TID:$a0
Max: 0.99939 Min: 0.3498
Test result value: 0.99927
PASS
MID:$22 TID:$a0
- Catalyst Monitor Bank 2
PASS
MID:$30 TID:$01
Max: 45,069 Min: 6,162
FAIL
MID:$31 TID:$05
Rich to Lean sensor switch time(calculated) - EGR Monitor Bank 1
Max: 41.113L Min: 4.144L
Test result value: 1.328L
FAIL
MID:$38 TID:$30
Max: 409.60001 Min: 5,641.7002
Test result value: 2,893.1001
FAIL
MID:$3a TID:$c0
- EVAP Monitor (cap off)
Max: 11L Min: 0L
Test result value: 1.673L
PASS
MID:$3a TID:$c1
Test incomplete or dependant test failed
MID:$3c TID:$c8
- EVAP Monitor (0.040")
Max: 0.65624Ratio Min: 0Ratio
Test result value: 0.02734Ratio
PASS
MID:$3c TID:$c9
Max: 0.72655Ratio Min: 0Ratio
Test result value: 0.00391Ratio
PASS
MID:$3c TID:$ca
Max: 1Count Min: 0Count
Test result value: 0Count
PASS
MID:$3c TID:$cb
PASS
MID:$3d TID:$c4
- EVAP Monitor (0.020")
Max: 6,553.5S Min: 40S
Test result value: 40S
PASS
MID:$3d TID:$c5
Max: 2,500Pa Min: -8,000Pa
Test result value: 32.75Pa
PASS
MID:$3d TID:$c6
Max: 60S Min: 0S
Test result value: 1.2S
PASS
MID:$3d TID:$c7
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count Min: 0Count
PASS
MID:$41 TID:$d3
Max: 2.481 Min: -4.211
Test result value: -0.177
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
Max: 2.481 Min: -4.199
Test result value: 0.178
PASS
MID:$45 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 1
PASS
MID:$45 TID:$d3
Test result value: -0.169
PASS
MID:$46 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 2
PASS
MID:$46 TID:$d3
Test result value: 0.5
PASS
MID:$61 TID:$09
Time between sensor transitions(calculated) - Heated Catalyst Monitor Bank 1
Max: 41,113 Min: 4,144
Test result value: 2,400
FAIL
MID:$71 TID:$1e
- Secondary Air Monitor 1
Test result value: 7,792
PASS
MID:$91 TID:$33
Max: 1 Min: 4,177
Test result value: 13,200
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 1Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
Test result value: 2Count
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
Test result value: 3Count
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
Test result value: 8Count
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
Test result value: 10Count
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
MID:$b1 TID:$18
Max: -48,846mV/s Min: 8,288mV/s
Test result value: 12,640mV/s
FAIL
MID:$b1 TID:$9c
Max: 40,978 Min: 26,816
Test result value: 6,624
FAIL
MID:$c1 TID:$10
Test result value: 4,288
PASS
MID:$e1 TID:$03
Test result value: 992
FAIL
MID:$f1 TID:$14
Manufacturer defined MID -
Test result value: 5,360
PASS
MID:$f1 TID:$59
Max: 41,113 Min: 20,528
Test result value: 23,024
PASS
End of report.
Test report:
MID:$01 TID:$01
PASS
MID:$01 TID:$02
PASS
MID:$01 TID:$03
PASS
MID:$01 TID:$04
PASS
MID:$01 TID:$05
Max: 189ms Min: 0ms
PASS
MID:$01 TID:$06
Max: 212ms Min: 0ms
PASS
MID:$01 TID:$80
PASS
MID:$01 TID:$81
PASS
MID:$02 TID:$8a
PASS
MID:$02 TID:$8b
PASS
MID:$02 TID:$8c
PASS
MID:$05 TID:$01
PASS
MID:$05 TID:$02
PASS
MID:$05 TID:$03
PASS
MID:$05 TID:$04
PASS
MID:$05 TID:$05
Max: 189ms Min: 0ms
PASS
MID:$05 TID:$06
Max: 212ms Min: 0ms
PASS
MID:$05 TID:$80
PASS
MID:$05 TID:$81
PASS
MID:$06 TID:$8a
PASS
MID:$06 TID:$8b
PASS
MID:$06 TID:$8c
PASS
MID:$10 TID:$01
FAIL
MID:$21 TID:$07
FAIL
MID:$21 TID:$a0
PASS
MID:$22 TID:$a0
PASS
MID:$30 TID:$01
FAIL
MID:$31 TID:$05
FAIL
MID:$38 TID:$30
FAIL
MID:$3a TID:$c0
Max: 11L Min: 0L
PASS
MID:$3a TID:$c1
MID:$3c TID:$c8
PASS
MID:$3c TID:$c9
PASS
MID:$3c TID:$ca
PASS
MID:$3c TID:$cb
PASS
MID:$3d TID:$c4
PASS
MID:$3d TID:$c5
PASS
MID:$3d TID:$c6
Max: 60S Min: 0S
PASS
MID:$3d TID:$c7
MID:$41 TID:$d2
PASS
MID:$41 TID:$d3
PASS
MID:$42 TID:$d2
PASS
MID:$42 TID:$d3
PASS
MID:$45 TID:$d2
PASS
MID:$45 TID:$d3
PASS
MID:$46 TID:$d2
PASS
MID:$46 TID:$d3
PASS
MID:$61 TID:$09
FAIL
MID:$71 TID:$1e
PASS
MID:$91 TID:$33
Max: 1 Min: 4,177
FAIL
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
MID:$a8 TID:$0b
PASS
MID:$a8 TID:$0c
PASS
MID:$a9 TID:$0b
PASS
MID:$a9 TID:$0c
PASS
MID:$b1 TID:$18
FAIL
MID:$b1 TID:$9c
FAIL
MID:$c1 TID:$10
PASS
MID:$e1 TID:$03
FAIL
MID:$f1 TID:$14
PASS
MID:$f1 TID:$59
PASS
End of report.
St. Jude Donor '08
Start over
Disconnect the battery.
Have it checked to insure it is charged and healthy. (reconnect or buy new battery)
Start the car and drive it.
Check for codes with a real code reader that gives code numbers that can be used to diagnose the exact problem from a GM service manual and provide exact diagnostic steps to be taken.
(i.e. B1420 - Device Voltage)
If codes result, check service manual for your car or the internet for diagnostic steps to be taken.
If no codes, then have it tuned by reputable Corvette tuner.
Mode $06, otherwise known as Mode 6, is basically hex-based data that the car stores as it continuously runs self tests on emissions related components.
If the scanner you are using lists data in the various Modes of the PCM, use Mode 3, which will list Diagnostic Trouble Codes (DTCs).
If you have any DTCs stored in Mode 3, start fresh by going into Mode 4 and clearing them. Then drive the vehicle for a few days to see what returns and start your troubleshooting from there.
Good Luck!
Good Luck!
