id1000 tn=uning map or help
im about to install a set of id1000 and i am wondering if anyone has a set of these and has a map i could use to run the car and drive it to my tuner or anyone that can help scale them thanks
All the info for them is on ID website. You don't say what year or engine your car is. If you need to scale, then you need to scale the whole tune, which is pretty in depth work.
All the info is copy and past from IDs website.
