Long and short fuel trim
Hello, I was wondering if any of the auto code scanners pick up the fuel trim? I stumbled over the subject of fuel trim and thought it would be a great way to check on the car for any intake leaks that don't register codes.
Thank you,
Sam
Thank you,
Sam
St. Jude Donor '13-'14-'15
There are several things that can cause either negative or positive fuel trims---The short term fuel trims as a tuner are of no concern---It's the long term ones that can indicate some issues--but they can vary---
A vacuum leak would cause both sides to go way positive
as long as it is POST MAF---a pre MAF air intake leak would simply just let un filtered air into your engine
If you have a medium difference between left and right sides that can simply indicate a small exhaust leak--
A major split between right and left can be a big exhaust leak or a failing front 02---
A dirty or clogged air filter would make the LTFT's go way negative on both sides
A fouled or oil saturated MAF from an oiled CAI could cause the LTFT's simply to go crazy and go either way
Normally to get a rich/lean code means that the LTFT's have gone beyond apprx 20% which is HUGE---
Most handheld scanners will read live 02 voltages and live LTFT's
if you dont want to buy a tuning device then grab a Datalogic device and you can configure it to read fuel trims along with any other PID you want. Plus you do not have to install a gauge in the car it reads out on the HUD.
