Just sent my PCM to ECS for Tuning
Just popped it in the mail for overnight today! Car is stock except for nxt axle back and corsa's pro5 cold air kit. Was throwing bank 1 & 2 lean codes after the install. Cant wait to get it back and see what kind of diff thsi made. Ecs was great to deal with over the phone
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,087 Likes
St. Jude Donor '13-'14-'15
Very common codes for high flowing cold air intakes as yours and the Vararam--Good news is that a lean code means that the engine is flowing more air than stock !!The ECM is adding fuel to compensate for the added airflow but it only helps you at P/T until your tuner corrects the leaness----At WOT you never want the ECM to have to correct the leaaness by adding fuel via your fuel trims at P/T --because at WOT that added fuel is added to the fueling as a safety which will make your car pig rich and lazy ---Rather confusing---added airflow will make it lean at P/T and rich at WOT----So you always want your fuel trims to be slightly negative or at "0" so NO fuel is added at WOT---
Your tuner will fix this-----Don't expect more WOT HP until he does---as I say it will be overly rich
