E85/Headers/CAI on a LS3, injector question
So on a LS3 C6 is anyone running those boltons and E85 with the stock injectors? I'm assuming I'll need bigger injectors and I've got a line on LSA injectors but before buying them I wanted to know if anyone got away with using the stock injectors. I can get the LSAs for $150, not sure if that's a good price. Without knowing the duty cycle of a stock LS3 I'm just guessing so if anyone can just tell me the stock duty cycle I can figure out the math.
Thanks in advance.
Thanks in advance.
$150 for the LSA is a good price.
From what I have researched, they should support ~525rwhp at 4bar pressure, NA on E85
60% x 42= 25, 25/52= 48% so that would leave 50% which would be eaten up by the mods and E85. Knowing what the stock duty cycle would be a big help.
LSA injectors (as long as you have enough fuel pump) will support around 580-600whp on E70. I typically bump people to ID850s when they're in that range though.
