sparkplugs for supercharged c6 running flex fuel
Taking the plung and going to start running a flex fuel kit in my 07 supercharged zo6. Now the heat range of e85 has me confused on what spark plugs to run and what gap. Can anyone point me in the right direction? mods are d1, arh, exhaust, titanium valses. msd fuel pump, id1300 injectors.
Pro Mechanic
Pro Mechanic
Once you get the engine running well enough to try some WOT calibration work, provided it's not starting out way rich, I'd switch to the IT-22. I'd stick with that unless you see clear evidence on the plug tip that it's running too hot. Then I'd go to the IT-24.
