injector question for tuners
I'm changing my stock ls7 42# injectors for some 56# ls9 injectors on a 07 z06. I have done hci and at wot my stock injectors are running at 102%. Question I have is do I use the injector scales from the ls9 and input those values in hpt?
injectors
Would you mind looking at a ls9 tune and giving me your opinion ? I can email one too you.
QUOTE=jim2092;1589647497]The idea is sound but the application may not be. Use injectors that have data that match the tables in your tune. Not having looked at an LS9 tune I cannot say.[/QUOTE]
St. Jude Donor '08
I was not able to find an LS9 tune to see if the injector data tables are the same as your 2007 LS7. But when I compared your LS9 injector tune to your stock tune, I see 11 changes to your stock tune under the Engine>Fuel>General tab that affect injector control. Did you make these changes? If so why and if you have an LS9 tune, do all the injector tables match the ones in your LS7 tune? It just makes it easier to swap data.
