C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
"S" Sport mode 1st gear re-program (A6)
Old 10-26-2015, 01:40 PM
Bruisr
Bruisr's Avatar
Default "S" Sport mode 1st gear re-program (A6)
When I'm in Sport Mode my transmission starts from a dead start in 2nd gear...unless I paddle down to 1st gear. Is there a program/advice etc that I could have the vehicle start off in 1st gear without paddeling through the gears?(or am I missing something)
Old 10-26-2015, 11:02 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
This is stock programming---A C6 and even the C7 with a 6 speed will only downshift into 2nd gear--Mostly because 1st gear is so low geared----
YES this is tunable with HP or EFILIVE----I drove my C7 with stock trans tuning and the trans would get hot very quickly as the converter slips a lot when starting in 2nd gear
So I re-programmed the TCM to allow the trans to downshift into 1st gear--but only at 1 mph or less----That way when you do a rolling stop and the car is moving somewhat it can start off in 2nd gear and not drop down to the low low 1st gear---Love it that way--
Old 10-27-2015, 12:40 PM
Sudstrain
Sudstrain's Avatar
Call Chuck CoW Corvettes of Westchester 1-914-332-0049 Chuck will be in Las Vegas for the SEMA show he can tune Your transmission.You won't belive the difference and yes you will have a first gear.
Chuck CoW (10-27-2015)
Old 10-27-2015, 04:43 PM
0Chuck CoW
Former Vendor
Chuck CoW's Avatar
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thank you Stan!
Thank you Stan! YES, we can fix that.... And lots of other stuff too!
Call any time! 914-332-0049
Chuck CoW
Old 10-28-2015, 05:59 PM
SouthBaySurfer
SouthBaySurfer's Avatar
My '08 starts in first from a dead stop in Sport mode. Try this from a dead stop in Sport: instead of paddling down to 1st, paddle up and see what gear it shifts into.
Once the paddles are used, it will only downshift to 2nd when coming to a stop,
which has been stated above.
To "S" Sport mode 1st gear re-program (A6)
Quick Reply: "S" Sport mode 1st gear re-program (A6)
