C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
P0466 problem
Old 11-29-2015, 03:19 PM
ron&suzn
Cruising
ron&suzn's Avatar
Default P0466 problem
I have replaced the canister the pump and it appears all lines are sealed. I tested the voltage at the selenoid under the hood and it was 13v. I cleared the code and it came right back. Is there a way to turn off this set of codes or does someone have some advise
Old 11-29-2015, 05:17 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Anyone with HP Tuners or EFI Live can disable the code altogether no problem. Takes 5 minutes.
Old 11-29-2015, 05:19 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Is it P0446 or P0466?
Old 11-29-2015, 09:12 PM
ron&suzn
Cruising
ron&suzn's Avatar
Originally Posted by schpenxel
is it p0446 or p0466?
446:d
Old 11-29-2015, 09:16 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Did you test continuity between the two pins on the solenoid itself?
There's another solenoid back towards the fuel tank, passenger side. Have you messed with that at all?
Old 11-29-2015, 10:04 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
YES P0446 can be permanently deleted so it will not re-appear---However I would delete ALL the EVAP codes as often one will sooner or later trigger another---
I would also check all the Evap lines to be sure you don't have a vacuum leak--as this can cause a lean condition from unmetered air entering your engine--You don't have to plug them off just make sure there are no leaks--
Old 11-30-2015, 10:50 AM
ron&suzn
Cruising
ron&suzn's Avatar
Yes I replaced the canister in the back as well. I did not test the continuity on the selenoid. It's brand new. I do not hear it operating like some of the post have said. The line going to it had 13vdc
Old 11-30-2015, 10:59 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I'd check continuity, at least on the one up front.. can't hurt.
Old 11-30-2015, 12:51 PM
BadAV
BadAV's Avatar
Received 2,673 Likes on 1,699 Posts
I recently went through this exercise on my Magnacharged 2002 Avalanche. It was the canister vent solenoid in my case. The evap canister and vent solenoid are separate components in my case. A replacement solenoid was only $28 and solved the issue.
Old 11-30-2015, 06:21 PM
ron&suzn
Cruising
ron&suzn's Avatar
I checked and did have continuity between terminals and checked the plug again and had 13.5vdc I plugged it back in and it started working. I checked the code it still has the code stored but it is not the throwing a new one??????
Old 11-30-2015, 07:06 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Just be glad it's fixed Don't ask why
Old 12-07-2015, 11:51 AM
ron&suzn
Cruising
ron&suzn's Avatar
Well it lasted about an hour and it's back any suggestions. Does anyone know who could remove the codes in the Dallas area
Old 12-11-2015, 06:51 PM
ron&suzn
Cruising
ron&suzn's Avatar
I checked the continuity and it did have continuity. It also had 13.5 vdc. Is it supposed to have continuity
To P0466 problem
Quick Reply: P0466 problem
