Diablo Tune
Diablo Tune
So yesterday I installed the tune on my car and went for a drive but could not tell a difference. So any other members here that have installed this tune my question is did you feel a noticeable difference?
Shifts are real firm and it feels stronger and is pulling harder thru 1st and second
Proud Owner (12-11-2015)
Maybe I need to reinstall. After installing car would not start. Freaked me out to say the least. Turned out it had killed the battery. Jumped started it and car fired up and drove without issue. So everything is back to normal but just not feeling anything from this tune.
The reason why I installed it is so I can get a custom tune done by DiabloLew . He asks that you put some miles using the Diablo tune and then record and send him a log file so he can fine tune it for you .
Dave
Wow you lucked out ! They warn u about the battery because you can "brick" the ECM if it dies while loading
I would start over and put a battery charger on it while loading
Dave
Dave
I had Diablo Tech on phone with me. He said that everything went fine loading tune. Told me to unplug and test drive it. So hung up and car just made a popping noise 6 times which I think would be the starter trying to do its job. I am thinking to go buy a new battery since this one seems to be weak. I have done this with other cars and never had this happen.
By any chance do you have an automatic ?
If so you should load the TCM tune . It really makes the transmission shift like a corvette should
I had a battery that would quit on my once in a while . I would charge it back up and a month later same thing . Just ended up replacing it and have had no problems since and sometimes my car might sit for weeks in the garage
Dave
Dave
Dave
Dave
Supporting Vendor
Sounds like you may have missed a key cycle or weren't engaging RUN mode with the start button if you wound up with a no start at the end, but it should be fine after cycling from Off to RUN, and off again.
I would restore the orginal tune and start over now that u have a good battery. Don't forget to cycle the key when it asks ...
Dave
What do ya mean cycle key? You mean put in accessory mode? I was on phone with Diablo the whole time. He said before battery died that it said tune was complete. But yea it is worth a try. I paid $380 for this thing.
I am telling you mine bangs 2nd so hard it breaks the tires loose ( and this is no bs) . Between the Diablo and my vitennese throttle controller my car is a different animal . Like I stated before I am not sure if it added power but is just pulls real hard all the way up to the shift point
Dave
Good idea to go back to stock tune then reinstall the 91 octane or the Diablo (93 octane) tune and the firm shift.
After you do that, get a custom tune from Lew @ http://www.diablewtune.com/ and it will really wake the car up. His tune works great with the Vitesse controller.
You should feel a substantial difference btwn stock and either tune, especially with the TCM tune. Remember, this doesn't add a bunch of hp, just makes the car drive like it should with better throttle response.
No I mean when it asks you to turn ignition on , press the button but don't have your foot on the brake , and then when it states turn it off . ........
Dave
Dave
With the stock goodyears it was violent with michelin pss it's more controlled
Absolutely 100 % agree , I had the same tires and just bought the Michelin PSS , I cannot describe how well my car runs now compared to when I bought it .
Even my daughter commented on how much the front end lifts when I punch it from a stand still and the shift into second is just silly , have not had the opportunity to feel the shift into 3rd yet lol
Dave
Dave
Dave
Also, all of the parameters that you have access to with the Diablo are a bit overwhelming. Have you played with any other settings or just loaded the canned 93 octane tune?
Hmmm... I have the same set up. Vitesse TC set on 9, Diablotune and firm shift. Do you have to stand on WOT to bark the tires in 2nd gear?
I have not played with any of the other settings yet , after the holidays I am sending my log files to DiabloLew for some tweaking
