Low dyno results?
Low dyno results?
07 ls2 vette with the following mods:
Hurricane Cold Air Intake
Yella Terra Roller Rockers 1.85:1 (non adjustable)
Texas Speed and Performance Push Rods
GM LS7 OEM lifters
PRT Stage 1 LS6 heads with double spring style valve springs
Comp Cams (Texas Speed Spec'd 228R Cam on a 115LSA)
Long tube headers and mid pipe from OBX with stock mufflers
Made 430rwhp after tune.
opinions?
Thanks everyone
GM LS7 OEM lifters
opinions?
Thanks everyone
GM LS7 OEM lifters
opinions?
Thanks everyone
GM LS7 OEM lifters
opinions?
Thanks everyone
I don't think your numbers sound too far off based on your mod list. I agree with Proud Owner, how does the car drive and feel? You can always get another test on a different dyno and chase a number if that is what you're after. If you are happy with how it feels, enjoy it!
It's not all about your final peak power......
What's more important is what were the baseline run numbers? The dyno is more a tuning tool, then a means for determining how much power you are generating or how fast your car will be. Also, what about power/torque under the curve?
Need to overlay the baseline over the final to see the overall improvements in the curve including peak.
Also, which dyno was used? Mustang Dyno/load bearing type are stingier than inertia type.
I would estimate 335/350 for a stock setup.
Ed M
Ed M
What kind of dyno? A million things factor into dyno numbers, such as what transmission, DA, correction factor etc....Like everybody else said, you should compare them to whatever base figure you might have. Bottom line, all that matters is how she runs and what kind of times she is able to lay down.
