Getting the most out of the Torque app
I am sure that plenty of you guys are using the torque app. What settings do you use? Has anyone completed a full scan for additional PIDs?
I used a refresh rate of 0.4 seconds (2.5Hz) and I normally log all GPS Data and the first 17 parameters listed below. On occasion when I messing around with stuff I've logged all 27. I can only log about 3-5 PIDs and achieve a refresh rate of 0.1 seconds (10Hz) I haven't be able to determine if its a limitation of the phone, software, OBDii module, or the car.
Here's what I have logged with success.
GPS Data:
* GPS Time
* Device Time
* Longitude
* Latitude
* GPS Speed (Meters/second)
* Horizontal Dilution of Precision
* Altitude
* Bearing
* G(x)
* G(y)
* G(z)
* G(calibrated)
PID Data:
1 Fuel Level (From Engine ECU)(%)
2 Intake Air Temperature(°F)
3 Ambient air temp(°F)
4 Transmission Fluid Temp (GM Method 1)(°F)
5 Engine Coolant Temperature(°F)
6 Oil Temperature (Engine)(°F)
7 Oil Pressure (Engine)(psi)
8 Accelerator PedalPosition D(%)
9 Throttle Position(Manifold)(%)
10 Engine RPM(rpm)
11 Speed (GPS)(mph)
12 Speed (OBD)(mph)
13 Air Fuel Ratio(Commanded)(:1)
14 Timing Advance(°)
15 Knock Retard(Deg.)
16 Volumetric Efficiency (Calculated)(%)
17 Run time since engine start(s)
18 Fuel Trim Bank 1 Short Term(%)
19 Fuel Trim Bank 2 Short Term(%)
20 Fuel Trim Bank 1 Long Term(%)
21 Fuel Trim Bank 2 Long Term(%)
22 O2 Volts Bank 1 sensor 1(V)
23 O2 Volts Bank 1 sensor 2(V)
24 O2 Volts Bank 2 sensor 1(V)
25 O2 Volts Bank 2 sensor 2(V)
26 Catalyst Temperature (Bank 1 Sensor 1)(°F)
27 Catalyst Temperature (Bank 2 Sensor 1)(°F)
Thanks for saving my from the full scan! I was trying to figure out when I would have time to make a long enough trip.
I cant wait for my android head unit to arrive so I can really get this going.
I use the: ScanTool 426101 OBDLink MX Bluetooth: Professional OBD-II Scan Tool for Android & Windows.
Amazon.com: ScanTool 426101 OBDLink MX Bluetooth: Professional OBD-II Scan Tool for Android & Windows: Automotive
I use the same ODBii Bluetooth Adapter to generate the following
PA_BLUE_C6 (03-16-2016)
Just installed a tablet onto my center console for the purpose of the extra gauges and data logging that Torque Pro provides.
(I may move it up higher for line-of-sight purposes.)
St. Jude Donor '05-'10-'12, '15
I cannot find a way to rerun the log files. I have phone storage logs, Torque website log files and log files in my pc. I have not found how to rerun them. Is it possible? It reruns the map route, but no clues how to study the graphs and gauges repeatedly.
Anyone else care to chime in on this one?
R_W (05-15-2016)
I'm not completely sure of the question, but I don't think looking at all the data in real time can be done via the app. I use excel to look at the raw numbers, but the easier way is to dump the files into a program like race render. Obviously the video part of the screen will be black but you can add dials to display all of the data you've logged.
PA_BLUE_C6 (05-25-2016)
I used 4 x Scosche "Magic Mount" (http://www.scosche.com/magic-mount-c...r-tablet-mount - Can be found on Amazon) dash pieces with the steel plates stuck to the bottom of the tablet.
Wilkinshc (06-01-2016)
Hope this helps.
