C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Just did a speed density tune
Old 03-12-2016, 10:44 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Which kit are you running?
Old 03-12-2016, 10:48 PM
Impulse20098
Impulse20098's Avatar
ECS 1500. Alky meth kit dual nozzle 100% meth
Old 03-12-2016, 11:02 PM
nightster
nightster's Avatar
Y'all are making wanna talk to my tuner about going SD/MAF. Impulse, who are you using for tuning?
Old 03-12-2016, 11:35 PM
Impulse20098
I'm switching tuners. And don't want to say until after car is tuned lol. In case car blows up haha. I'll let you know Monday afternoon. I'm located in Houston though. Not sure where you are.
Old 03-12-2016, 11:37 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Just crank the meth up and you'll be fine.
Old 03-12-2016, 11:46 PM
nightster
nightster's Avatar
Gotcha. I'm not far from Houston, down 59s, I drive into Houston for work...
Old 03-13-2016, 09:56 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Just to be clear, this isn't an ECS kit issue. All kits have the same exact issue with mafs.
Even NA cars have that issue.
Old 03-13-2016, 12:19 PM
Impulse20098
Correct. Sorry I should have explained that.
Old 03-13-2016, 12:29 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I always wondered if the dent right before the MAF on ECS's tube makes MAF readings worse at lower airflows. I tried to order one without the dent but they didn't have any in stock and I didn't feel like waiting, so I just got the no MAF version.
Guess I'll probably never know
Old 03-13-2016, 09:44 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I'll disagree. Running MAF only and airflow is perfectly smooth. I get no surging, hesitation, etc. When I moved my MAF to a bad spot (bad decision) I was getting surging like crazy. The placement and airflow over it make all the difference.
I am going to play with blending the tune this spring but won't switch to SD only. MAF has been flawless on both my supercharger systems so far.
Old 03-13-2016, 11:40 PM
Unreal
Unreal's Avatar
Well, it isn't an ECS exclusive issue. Other kits, and intakes have same issues. If maf isn't in a good spot, lot end/tip in/etc can suffer.
I never had an issue with running maf only. Drove great. Just SD drives better.
Old 03-14-2016, 08:05 PM
speedz06
speedz06's Avatar
Ok, so maf positioning, and whats this about the ZR1 map sensor....have to check if the eforce kit came with a new map sensor and what the deal is.
Old 03-14-2016, 08:19 PM
  #33
schpenxel
schpenxel's Avatar
St. Jude Donor '15
SD mode needs a MAP sensor capable of reading boost. A ZR1 sensor is an easy option for most.
Old 03-14-2016, 08:21 PM
  #34
realcanuk
realcanuk's Avatar
St. Jude Donor '13
An eforce comes with a TMAP. Map and temp sensor in one. It is in the rear of the blower and works perfectly. You will want to tune with it.
speedz06 (04-24-2016)
Old 03-14-2016, 09:43 PM
  #35
Impulse20098
Just got the car retuned. Matt from FSP tuned it. Car runs amazing.
Old 03-17-2016, 08:23 PM
  #36
nightster
nightster's Avatar
Nice, I've heard good things about Matt. I found out Sunday he was coming into town this week.
Old 03-25-2016, 11:36 AM
  #37
MickVette
MickVette's Avatar
St. Jude Donor '13
Can the car be used to MAP only at idle up to a certain throttle percentage then switch over to MAP/MAF combo? I have HPTuners and am still on the learning curve here.
The car is an '09 ZO6 and the mods are as follows:
- Halltech MF103 Intake
- Nick Williams 102mm TB
- MSD Atomic Air Force Intake Manifold
- Advanced Induction 280CC heads, BTR springs, Ferrea 2042P Exhaust valves
- EPS (Engine Power Systems) custom grind cam - 232/246 duration, .639/.639 lift on a 115+3 LSA
- Kooks 1 7/8 Long Tubes, 3" Catted X-pipe
Current drivability is bucking off idle and any cruising 1500 rpms and lower has a lot of surging.
To Just did a speed density tune
Old 03-25-2016, 11:54 AM
  #38
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Just run SD and be done with it
  #39
Impulse20098
The surging is most likely related to your cam.
Old 03-25-2016, 01:25 PM
  #40
MickVette
MickVette's Avatar
St. Jude Donor '13
I agree the camshaft is the source of the surging and poor idle quality (reverse pulses through the MAF totally confusing it - you can see it on the log play back via wide frequency range all at idle).
I want to try MAP for idle up to about 1500 rpms then switch over to the MAF/MAP combo that is currently used. Does anyone know the specifics how to do this in HP tuners? I have a wideband so I can tun the MAP table once the MAF is disabled, but I would like to keep both sensors active in case one fails.
Quick Reply: Just did a speed density tune
