codes on an automatic z06
I have a few (or a lot) of codes that are preventing me from passing emissions around here that ive been trying to get rid of. For some of them such as the fuel level sensor, the 02 codes I suspect are just a faulty heater on the driver side. I am suspecting that the BCM is going. I replaced the Crankshaft position sensor less than 1,000 miles ago, and the code for the camshaft sensor just started going last night. The car is a 2008 z06 with a 4l65e swap done by RPM transmissions.
[] P0030 - HO2S Heater Control Circuit (Bank 1, Sensor 1) (Pending) (Old) (History) (Current) (Immature)
[] P0053 - HO2S Heater Resistance (Bank 1, Sensor 1) (Old) (Current) (Immature)
[] P0135 - O2 Heater Circuit (Bank 1, Sensor 1) (Old) (Current) (Immature)
[] P0174 - System Too Lean (Bank 2) (Old) (Immature)
[] P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor) (SES) (Pending) (History) (Immature)
[] P0496 - Evaporative Emission System High Purge Flow (Old) (Current) (Immature)
[] P0502 - Vehicle Speed Sensor A Circuit Low (Immature)
[] P0713 - Transmission Fluid Temperature Sensor A Circuit High (Old) (History) (Current) (Immature)
[] P0801 - Reverse Inhibit Control Circuit (History) (Immature)
[] P0803 - Upshift / Skip Shift Solenoid Control Circuit (Pending) (History) (Immature)
[] P0808 - Clutch Position Sensor Circuit High (Pending) (Old) (History) (Current) (Immature)
[] P2066 - Fuel Level Sensor B Performance (Old) (Current) (Immature)
[] P2068 - Fuel Level Sensor B Circuit High (Pending) (Old) (History) (Current) (Immature)
[] P2636 - Fuel Pump B Low Flow (Old) (History) (Current) (Immature)
[] P0335 - Crankshaft Position Sensor A Circuit (SES) (Pending) (History) (Immature)
[] P0336 - Crankshaft Position Sensor A Circuit Range/Performance (SES) (History) (Immature)
Received 1,193 Likes
St. Jude Donor '15
First four are probably just from a faulty O2 sensor.
About half of the rest sound like codes that need to be disabled because of the transmission swap and then the sensor ones I'm not sure about. All of them can be disabled if you just need to get through emissions testing
