idle hang
idle hang
Any ideas on the 1500 rpm idle hang? Cleaned the T-body and maf and now it hangs at 1500 rpm's until til the car comes to a dead stop. Any ideas how to fix?
Received 1,194 Likes
St. Jude Donor '15
Min airflow is an obvious first thing to mess with tune wise.
Ensure there are no vacuum leaks as well
St. Jude Donor '15
Table that controls how far the throttle blade closes basically
when the car drives for a while it idles at about 1500 rpm when the clutch is depressed and the car is still moving....as soon as you come to a stop 2-3 seconds later it goes back to its normal idle so I don't think the throttle blade is off....would it not do it continously if that was the problem....it's been doing it for a couple of years now....it's frustrating because it doesn't do it all the time.....
St. Jude Donor '15
Most people that install SC's or cams have the opposite problem where when you push in the clutch when moving it dies or starts idle hunting really bad, and that's usually from the min airflow table being too low. Once they're stopped adapt idle is active and they are fine. C6's don't have a throttle cracker table in the same way C5's do.
If it's a stock car/tune it shouldn't be doing it regardless though.. If it's modded and/or had any tune changes then it's anybody's guess. Without being able to log what's going on it's going to be a guessing game
mine is completely so k for the moment other than wheel brakes spoilers.....the engine was never touched other than regular maintenance......oh well I'll just keep digging.....
St. Jude Donor '15
I'd swap out throttle body then and see what happens
I also have this problem. It drives me nuts. I have ported heads ,cam ,intake ,nw102, and headers though. Clutch in coasting car idles normal. Clutch out coasting out of gear it idles at 1500. My tuner says that it's part of GMs programming and I just noticed it cause all the changes I made. I just bought an hp tuners set up and a training book so one day I can get to the bottom of this hopefully. I'd like to say thanks to schpenxel . He is a major contributor to this fourm and HP tuners fourm. I know he spends a lot of time answering tune related questions and helping fellow enthusiasts with how to articles.
St. Jude Donor '15
There's a different section of min airflow table for every gear + neutral and reverse, so I suspect that's what it is on yours too. On M6's I think it only uses neutral, reverse and 1st gear but haven't messed with it in a while. He's right that GM sets them up to behave differently depending on in gear, neutral, reverse, etc., but that doesn't mean he had to leave it that way
I'm almost sure clutch in vs. out will use different sections of the table. It's been a while since I've had to mess with it, but you can log "trans current gear" to see how it's behaving and get a better idea what area to mess with
If the car has been tuned before I have noticed that alot of tuners change the spark table while at coast. When they bump this up it will have a high idle at coast till the car comes to a stop. With EFI live it is table B5122 and even says that table can be used to change the coast idle. Mine was custom tuned by a tuner on here and after I noticed that had a high idle like a cruise control effect while slowing down. i found that table and put it back to stock and it was back to normal
St. Jude Donor '15
Yeah, more spark or more air flow can both do it. I don't mess with the coast down spark tables a ton but you're right, that can do it too
yea the tuner that did mine bumped that table alot for whatever reason. It was doing the high idle bad. It would hang at 1500 till I made a complete stop. I just started comparing his tune he did for me and my stock tune and just stumbled upon that table. After putting it back stock it was good. I could see where that would be useful with a very large cam possibly but is a bit overkill for a stock or small cam
St. Jude Donor '15
Depends on how bad it's doing it. Yes idle RPM is set higher when moving, but not by much. 100 RPM's at most
