C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
LS7 dont start, HP tune scan attached
Old 05-18-2016, 03:43 PM
AndreasK
AndreasK's Avatar
Default LS7 dont start, HP tune scan attached
Finished building a ls7 and get no luck starting it. Can someone please look at the attached vcm scanner file to se if you se any errors? My guess would be either to low battery power or a forgotten cable. Got a brand new battery on a sunday and a 56amp was the only one i could get, could try starting it with cables in a few days.
File Type: hpl
Old 05-20-2016, 05:03 PM
jatolbert
jatolbert's Avatar
Battery is fine. 12.25V at startup and it seems to be turning over fine. Issue is somewhere else.
Is this the first startup attempt of the new engine? Is the LS7 a stock rebuild or any modifications?
Old 05-22-2016, 04:01 PM
AndreasK
AndreasK's Avatar
Its unchanged from before it broke. So only the block is changed. One os2 sensor was not connected and also there was a faulty hose connection to the fuelrail. Haven tried after these were fixed. Next step will be checking the ignition.
Thanks for the input
Old 05-22-2016, 09:37 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Add injector PW to the list of stuff you're logging
Old 05-23-2016, 04:51 AM
AndreasK
AndreasK's Avatar
Great, was not sure wich parameters to log.
To LS7 dont start, HP tune scan attached
Quick Reply: LS7 dont start, HP tune scan attached
