C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Timing for a ls2 blower car on e85
Old 05-24-2016, 01:27 PM
curtisb23
curtisb23's Avatar
Default Timing for a ls2 blower car on e85
Wondering what kind of timing I can run on my blot on blower car with e85 it's currently running 19 degrees timing. What's kind of timing do yall run ?
Old 05-24-2016, 09:36 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
How much boost?
Old 05-24-2016, 10:00 PM
curtisb23
curtisb23's Avatar
About 14
Old 05-24-2016, 10:02 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
That's about all I'd run personally with that much boost on an LS2. I'm at around 16.5*, 12psi or so, gasoline+meth though. No knock. M15 nozzle, controller on 10
Dude_man is running a turbo setup on E85, think he's running about what you are timing wise. If I run any less mine feels like it loses a lot of power after 4,200
Old 05-24-2016, 10:39 PM
curtisb23
curtisb23's Avatar
I'll prob up the boost alil more 3.6 pulley to a 3.47 .I'm about 200 hz from running out maf I believe
Old 05-24-2016, 10:42 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Forget the MAF, SD FTW
Old 05-24-2016, 10:56 PM
curtisb23
curtisb23's Avatar
Yeah lol .I'll need a bigger map sensor lol.I did a ls2 maf but guess it's not big enough I guess
Old 05-24-2016, 10:57 PM
curtisb23
curtisb23's Avatar
I'm not scared about my ls2 she's a good motor lol
Old 05-24-2016, 11:04 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
DSX has a 2.5 bar for E40's if you're on that ECM
They hold up so well on E85, it's crazy. I've considered switching to it just to not have to worry about the motor.
Old 05-24-2016, 11:13 PM
curtisb23
curtisb23's Avatar
I'm on w.e ecm came with the car lol I think it's a 38??... 200y base ls2 .
Iv been told the ls7 maf can read alot of power and I'm about out lol idk what's up
Old 05-24-2016, 11:27 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Not sure what a 200Y model is
2005's were E40, all the other LS2's were E38's
LS7 MAF range will depend on size tube used. What size charge tube are you using? Are there any OS upgrades available for that ECM? A lot of the E38 custom OS's that HP Tuners has extends the MAF range, but it's an OS by OS thing, so hit or miss on whether you can get it or not.
Old 05-24-2016, 11:45 PM
curtisb23
curtisb23's Avatar
Dam phone lol .2006 * so it's e38 ecm
.I am running the a&a 4in charge pipe. I'm not very good with the letter terms (os) I don't know what you mean there haha.I also have id1000 so My tune is all kinds adjusted lol
Old 05-25-2016, 07:47 AM
curtisb23
curtisb23's Avatar
I ran that timing on straight 93 with 14 psi car made 704 on a Mustang. Then 4 months later for tune on e85 it made 685 on 93 14psi didn't change anything but the time of year
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I'm surprised you're maxing out a card MAF in a 4" tube. See if there's an OS upgrade available to extend the MAF range if you want to keep using the MAF
Old 05-25-2016, 07:48 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
19 degrees, 14 psi, 93 and no meth? Or 16.5*?
Old 05-25-2016, 08:08 AM
curtisb23
curtisb23's Avatar
What is os ?lol
Old 05-25-2016, 08:09 AM
curtisb23
curtisb23's Avatar
16 degrees 93 only 14 psi
To Timing for a ls2 blower car on e85
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Operating system
HPTuners has some upgraded ones that can be installed. Some of them extend the MAF range and have a bunch of other features. The details vary by ECM/OS though so not sure exactly if it would gain you more MAF range or not on yours.. it's free though if the tuner is already using HP Tuners.
Old 05-25-2016, 08:15 AM
curtisb23
curtisb23's Avatar
I'm about 200 hz from maxing it . I am gna see if I can get away with a 3.47 pulley from my 3.6
curtisb23
curtisb23's Avatar
Do you mean like hpt?
Quick Reply: Timing for a ls2 blower car on e85
