C6 Vent controls not working
I just bought a c6. The AC works but just blows air on my feet and out the pillars on the sides. No matter what you put the selection on the climate control on, it does not switch. My AC guy tells me that you have to take it to the dealer to have them read the body codes that will tell you which actuator (all electric) is not working. Fuzes all look good.
My question is this. Is there a program like HP Tuner that you can buy that will give you this troubleshooting capability? I have no recourse here in the Arizona heat than just taking it to the dealer and hoping I don't get screwed too bad. Anyone dealt with this?
Thanks,
Thanks,
Received 1,194 Likes
St. Jude Donor '15
HPT can't read BCM codes as far as I know. Only ECM and TCM
I have a similar issue with mine, with the additional bug that the automatic fan speed control no longer functions. Manual speed/temp control works fine.
Fortunately for me, the system is stuck with the primary vents open, so I still get the heating/cooling that I need. The dealership I bought my car from is so violently afraid to touch my car now that I have a cam in it that I'll probably end up replacing the AC control unit and all the actuators myself. The car is out of warranty so I'll be paying for the parts anyway - no sense in paying for the labor to swap out parts that will take me 30 minutes to do anyway.
Eventually I'll get a tech 2/clone, but until then I'll have to settle for the "replace stuff until it works" approach. Eventually it's bound to work!
The default or "stuck" position on mine has the vents open on the pillars and under the dash so I can't get air to flow but a smidge out of the center top vents. Needless to say here in Tucson where it's getting up to 115 deg right now it's not quite optimum. The dealer is telling me the mode actuator can't be accessed through the glove box opening but that's BS according to my friends here on the forum. Moot point though because they discovered the door that the actuator works was broken and had to order a new one which means the whole dash had to come out. Will be 11 hours of labor and 100 bucks worth of new parts. Sheesh. My C6 is brand new (at least to me) with only 15K miles on it even though it's a 2005. 6-speed (real sports car :-)) I didn't go into hock to get it from CA just to not use it so, oh well, getting bent over by the dealership. If it had a few more miles on it and didn't look brand new I'd be wrenching.
