Need Help With Code P2534
Here are the list of codes the Vette is throwing
6/28/16
[] P0700 - Transmission Control System (MIL Request) (Pending) (Old) (History) (Current) (Immature)
[] P0562 - System Voltage Low (Old) (History) (Immature)
[] P0826 - Up and Down Switch Circuit (History) (Immature)
[] P2534 - Ignition Switch Run/Start Position Circuit Low (SES) (History) (Immature)
Basically it has thrown the P0700 and P2534 codes intermittantly for a while. The first time was 6/29/15, then 12/24/15, next 6/21/16, and now. I was thinking it was just a loose connection or something, but now I'm getting worried it's more serious (transmission or TCM). I have searched here and HPTuners forum several time and found very little info. The car has had a tranny tune in it since 08.
This is my wife's daily now and it has been throwing these codes and not shifting which is causing the transmission to get really hot.
Thanks for your help!!!!!
6/28/16
6/28/16
6/28/16
I regret to hear that your Corvette seems to be pulling these codes, and I can understand your concerns. If you would like to bring this to the attention of your dealer to get a formal diagnosis, I would be more than willing to offer you additional assistance with doing so. Please don’t hesitate to send us a private message if this would be of interest to you, or if you have any other questions.
Have a great day,
Angela O.
Chevrolet Customer Care
Have you checked your battery ?? My CTS was throwing transmission codes and it was my battery
Dave
Dave
I haven't checked my battery because it was replaced not too long ago, but I will check that out. The codes were thrown again last night as my wife was leaving an event. I had to grab my computer and drive to meet her to clear the codes. I drove it back home just in case it happened again.
Called Onstar because i had activated it for my wife who was the primary driver
The girl who answered ran remote diagnostics on the car whike i was driving and advised me that the TCM has sent a low voltage code to the ECM and it looks like the battery dropped a cell . She told me to restart the car , which allowed it to start shifting again but still had a cel
then she called a dealer and they were waiting for me with test equipment and battery as I drove into the service lanes . Test confirmed that the battery in my 2 month old car dropped a cell
Drove the car for 3 years after that without any hint of an issue
Moral of story .... check your battery and the connections , u have multiple low voltage codes ..... then check the alternator as there are more than one report of them dropping dead
Just my two cents ......
Happened again today. The wife was around an hour away. The car threw the P2534 and P0700 codes, transmission was stuck in 3rd and would not shift up or down. I had her try paddle shifting it and it wouldn't shift that way either. She had to go back roads (35-40mph) to get home. When she got home the transmission temp was 226-230*. Luckily it was a cooler night tonight.
I can't believe nobody else had this problem before. I'm afraid if I take it to the dealer they are just going to start changing out parts trying to figure it out costing a fortune.
I had very similar issues back in 2013. I took it to the dealer because it was under warranty. The 3rd dealership finally fixed it. They called Detroit for help after I did. My issue wound up being the BCM. (body control module) the board had a hairline crack in it that would lose contact under different weather conditions. Good Luck.
