C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Local shop doesn't want to install ECS with SD, only MAF...
Old 07-08-2016, 11:18 PM
Dimewise
Dimewise's Avatar
Default Local shop doesn't want to install ECS with SD, only MAF...
All the reading I've been doing makes me want to go SD with the ECS kit, fuel and meth system.
The tuner is a local guy that is fairly well known and does great work from what I've been hearing. They have plenty of 1xxx hp cars with MAF which is mostly why they prefer it I guess.
Should I be concerned?
Houston car. 11' GS A6.
Old 07-09-2016, 07:17 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Nothing wrong with using the MAF if he can get it to work smoothly. It seems that is tougher to do with the ECS setup due to the placement of the BOV. He should be willing to tune SD if necessary, even though it takes a bit more time.
Old 07-09-2016, 09:41 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,079 Likes on 653 Posts
I can either send a file or put an SD tune in the ECM for you so they will only have to do minor touch ups on it if anything. N/C
Old 07-09-2016, 10:41 AM
stab1991
stab1991's Avatar
Its just the difference in source for airflow figures right? MAF or VE table dependent I believe. But on the LS isnt it both anyway.... MAF with SD taking over when the MAF data is erratic ( at idle and such). My LS memories are a little foggy.
Old 07-09-2016, 02:49 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I seriously doubt it is the placement of the BOV causing any issues. If anything it is the maf pipe and placement of the maf.
Old 07-09-2016, 02:53 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
I dunno. I see the pipe and MAF in similar spot as others. Main difference seems to be placement of the bov.
Old 07-09-2016, 03:31 PM
schpenxel
schpenxel's Avatar
Received 1,193 Likes on 1,052 Posts
St. Jude Donor '15
Yeah, it's mixed mode on stock vehicles. Stock above 3500 RPM's they are MAF only, under that mixed mode. Just different ways of calculating airflow.
I can only say from my experience with the ECS kit I would prefer an SD tune. Take Doug up on his offer for a base file--he does so many of these things it should be really close.
MAF can absolutely work just fine in the right setup. For whatever reason there seems to be too much turbulence on ECS's setup. Whether that's from MAF placement or BOV placement, I have no idea.
Old 07-09-2016, 03:51 PM
Unreal
Unreal's Avatar
SD is preferred on ANY kit. I just don't get the recent "ECS kits needs SD" crap.
Old 07-09-2016, 03:56 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Not sure it's crap. My tuner just did an ECS kit for a member here and couldn't get it running well on MAF. Did it SD and it's working great. He's done many A&A kits, and procharger since he's a dealer, and never has that issue. Mine also runs great on MAF.
Either way, I don't really know or care, but the main difference is the bov placement so I would assume it's that.
Old 07-09-2016, 04:35 PM
Unreal
Unreal's Avatar
ECS kits maybe more sensitive to maf issues, but don't need a SD tune. In this OPs case I would do what the tuner wants, but make it clear to them if you are not happy you are not repaying for them to do the SD part.
Old 07-09-2016, 04:42 PM
Dimewise
Dimewise's Avatar
Thank you, Doug!
What all would you need from me to put the SD tune on? The car will have yalls stage 1 fuel and alky kit too.
Old 08-23-2016, 11:04 AM
DOUG @ ECS
DOUG @ ECS's Avatar
Originally Posted by Dimewise
Thank you, Doug!
Either send me the ECM, or if your tuner uses EFI live I can just email a file.
Old 08-25-2016, 11:32 AM
Speedforhire
Speedforhire's Avatar
SD tune gets my vote also............
To Local shop doesn't want to install ECS with SD, only MAF...
Quick Reply: Local shop doesn't want to install ECS with SD, only MAF...
