C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
2007 C6 electrical issues when hotter than 85° outside.
Old 07-20-2016, 09:59 AM
etdobbs
etdobbs's Avatar
Default 2007 C6 electrical issues when hotter than 85° outside.
My C6 has been experiencing electrical issues (mainly will not start) when parked outside in temperatures above 85°. It can drive and does not die in any temperature. The issue arises when shut off and let sit for a couple minutes. It will not restart until it cools off (either later in the evening or if I push it in the garage).
Symptoms when above ~85°:
- doors and trunk will not electronically open
- when trunk is opened manually, alarm will not go off
- FOB alarm button does not work
- FOB not recognized in glove box slot
- ignition and accessory buttons do not respond. (no gauge response and no DIC "FOB not detected" message)
- "Service Vehicle Soon" apppeared on DIC once when it cooled off enough to start.
- trunk and dome lights will work
- on/off button will show radio time
I am still working diagnosis.
When it cools off, everything comes back to life. Alarm will go off, ignition will be on. Whatever buttons I touch to get it started seem to be remembered. It will startup immediately and have no issues.
My current plan:
- further inspection of battery (~8 months old)
- check the 12 main frame ground points (nice write ups on this by forum members)
- inspect connections at BCM, RCDLR, and instrument panel
- when above 85°, remove RCDLR and instrument panel and bring inside to cool them down.
Questions:
- has anyone experienced this type of issue before?
- are there any other modules or areas that I should be considering?
Thanks in advance for your input.
Tim..
Old 07-22-2016, 07:56 PM
etdobbs
etdobbs's Avatar
I think I found it. Thanks for looking.
Old 07-23-2016, 12:16 PM
Got uid0
Got uid0's Avatar
St. Jude Donor '17
what did you find
Old 07-24-2016, 11:56 AM
etdobbs
etdobbs's Avatar
After much trial and error indicting the systems mentioned above, I believe one of my serial data wires was selectively contacting a 12V+ wire. The source was at the black connector of the gauge panel. All cleaned up and running good over the last three 95°+ Iowa days.
To 2007 C6 electrical issues when hotter than 85° outside.
Quick Reply: 2007 C6 electrical issues when hotter than 85° outside.
