Safe to Start 402 Stroker before Tune?
Background:
I have a 2005 Corvette Z51 6 Speed, I bought it 6 years ago, and it came modified. A few months back that engine died, you can see pics here.
Since then, I have worked with TSP to build a 402 Stroker, and just this week got the completed engine back from the machine shop - and I'm ready to install it this weekend.
My Question Is:
Will it be safe to start the new engine with the the tune from the previous build? And do some loading for break in prior to driving to the tuner?
I had originally planned on reading the current tune, sending it to Tom Wong (my tuner) for quick modification - and then flashing it back in preparation of the first start. But I'm unable to read the PCM w/o the engine in the car. (Thread about this issue here)
Thanks,
Dan
My Question Is:
PREVIOUS BUILD 448hp 396 tq
Custom ground Cartek 2x cam (230/234 .591/.598 116 LSA)
Comp 921 springs
Titanium retainers, milled .030 and fully cleaned with assembly
Cromoly hardened push rods
Notching of pistons for clearance
(These Parts carry over into the new build)
Cartek Racing Stage 4x Cylinder Heads (243 cast CNC Ported w/ 2.02" Manley Valves)
Vararam cold air intake
Corsa Sport Exhaust
Kooks 1 3/4" Long Tube Headers
Kooks hi-flow cats & x-pipe
160 degree thermostat
ASP Underdrive Pulley
Ported FAST 90mm intake to stage 2x
Comp 921 springs
Corsa Sport Exhaust
CURRENT BUILD
TSP Forged 4.00" Crank
Weisco Forged -8cc Pistons
Eagle H-Beam Rods 6.125
TSP 233/239 .600/.600 113 LSA 110ICL Camshaft
42# FIC Drop In LS2 Replacement Injectors
PRC 660" Dual Valve Spring Kit
TSP 7.40 Chromoly Pushrods
Melling High Pressure Oil Pump
GM LS7 Lifters
Cometic .040 Head Gaskets
COMP LSx Rocker Arm Trunion Upgrades
SPEC Stage 2 Clutch
SPEC Billet Steel Flywheel
(These parts carried over from the old build)
Corsa Sport Exhaust
GM LS7 Lifters
SPEC Stage 2 Clutch
Corsa Sport Exhaust
Thanks,
Dan
