Help with hp tuners fan settings
I got my cars tune changed from mass air to speed density and the next day I noticed my car was running a lot hotter with the AC on that it had before.my ECT versus percent is actually set too high but I need help interpreting what this set up means on the Ac setting
Received 1,194 Likes
St. Jude Donor '15
leave that table stock.
What does the ECT one look like?
That one is saying when the AC system pressure is at say 1475 kpa then set the fans to 52%
There's an ECT one also that will just say if ECT is 210* then set the fans to 80% (or whatever, just an example)
Whichever is higher is what it uses.
I also have changed my fan to the same one you suggested before( I think
Derale or something which had been working great.
Now I feel air moving from fan but not that hard.
St. Jude Donor '15
Shouldn't go over 90% on C6's w/stock controller. If it's been at 100 for a while then the connector or controller are probably fried.
