engine indicator light
DECON BLUE (06-01-2021)
go to o'reilly's, napa, autozone, and they will read the codes for free. If they cannot tell you want the code is for then you can post back here with the code number. Someone will be able to tell you what the code is for and probably what it takes to fix it.
Your owner's manual does not list the codes and what they are for.
