GM E38 OS 12653249 conversion to 2bar SD conversion
Moving to 2bar shows 6800 RPM limit on VE tables.
Any way to increase this limit?
Looks like original OS used coefficients to calculate VE rather than a table.
OK to copy over someone else's VE table from same LS3 tune to get me going?
Received 1,193 Likes
St. Jude Donor '15
You can click on the axis headers and change the MAP/RPM axis break points to whatever you want within reason
E38 2 bar OS's are generally set up to go up to 175kpa by default--I would change it up to whatever the max boost value you'll ever run is and a little higher. Same for RPM. This is a pain to change later. If 175 kpa is enough then leave it as-is (it's around 11psi boost)
Then open up your original tune, open VVE editor. Same thing, click on the axis for MAP, change the values to match whatever you used in the new tune. Same for RPM.
Now copy the whole factory table, paste it into Excel.
Copy it in Excel, paste special / transpose somewhere else. That will flip the X/Y axis around (VVE and regular VE are backwards)
Then you should be left with something you can paste into the new 2 bar OS tune.
There is probably an IMRC open and closed VE table, I just make them the same. Only one is used on Corvettes but I can never remember which
For whatever reason this never works out "quite" right... every time I've done this fueling has been off 10-15% from where it was when using VVE, but it's at least close enough to get the car started.
Any negative side effects of going 0 - 8192 RPM range? Easier for me working with base 2
Is the VVE editor built into v3.2x or a separate utility
thx
thx
St. Jude Donor '15
Built in. It's under edit I believe
8192 should be fine. You lose some resolution throughout the table if it goes that high but not a big deal IMO.
St. Jude Donor '15
Right, it doesn't exist in the upgraded OS--uses regular VE tables instead
Uggh.. I have to manual enter the axis settings since VVE doesn't interpolate or use one of their "canned" ranges.... but selecting a canned range crashes and says "Report this error to HPT".
I get the drift here and should be able to get it going one way or another and will post the tune later on if you'd be kind enough to take a look.
St. Jude Donor '15
Yeah just post it up whenever. Honestly you're just looking for something close enough to get it started.
You should be able to copy the axis values out of the 2 bar OS then paste them into the VVE axis settings
A whole afternoon of reading shows VVE uses settings under Dynamic to generate the table and I get some strange looking tables when adjusting Boundaries for higher RPM and Kpa as well as the coefficients.
Hard to believe it's this difficult to generate a simple table to get me going
Here's the result... Doesn't look right to me though
St. Jude Donor '15
Email me and I'll send you a VE table to start with, I'll PM you my address
I would keep as much resolution as possible. No reason to goto 8200. Go ~200rpm past your fuel limit. No reason to have a good chunk of map that you can never use.
Wound up generating a map with Bluecat, using a somewhat close characterization to my mods and used Excel to scale it into my kpa and RPM limits (175kps vs 7200 RPM) .
After going through this, confidence on setting this up properly is down to about 80% and might check out ECS for a base tune to get me going. Well worth the $149 bucks if that's the going rate.
VE %
Airflow:
