2005 c6
2005 c6
I v'e 2005 C6 and when i start the car the dashboard works probably a minute or less later it starts to blinks and then turns off and the digital board shows the ABS and other systems are not working.
any one knows what's the problem?
thank you.
thank you.
Check grounds
I have same year and recently had DSC and Antilock errors popping up. It was a bad ground on one of the frame rails.
Received 1,193 Likes
St. Jude Donor '15
Ground issue isn't unusual when you get a bunch of errors randomly at once like that
