HP Tuners Log
HP Tuners Log
When reviewing my log after a run I determined that the log show me never going more that 83.9% Throttle (TPS). I can assure you it was mashed the entire 1/2 mile. Is this a normal thing or do I have an issue. The event was still wicked fun, just now I wonder do I have an issue? Thanks in advance, I'm still in Indiana and couldn't login to HP Tuners. Beside I figured it might be a vette thing or something. Again thanks in advance, See attached.
Received 1,193 Likes
St. Jude Donor '15
That is normal
(though fuel trims are at like 25% at idle.. probably want to work on that)
The following 2 users liked this post by schpenxel:
Dcasole (10-16-2016),
Steve Haefner (10-17-2016)
This is good to know , I was just looking at my logs and saw the same thing and had the same question
Dave
Dave
Sounds good on the fuel trims at idle, now if I only knew how to work on that lol. Super new to tuning myself, in-fact may never really tune it myself, but what the ability to see / ask for advise as I have done here.
It was tuned by a very solid tuner in the area and maybe because he tuned it in Feb the trims are off? Also that was like my 2nd run within say 20 mins or so, otherwise I'll take any advise. Thanks again schpenxel!
Event was great, my best was 145.767 mph
St. Jude Donor '15
Yeah, it only goes to 83'ish % for whatever reason. I don't know why, but it's normal for it to report like that, so nothing to worry about and nothing to fix
Great! If you are bored let me know about this fuel trim at idle and I should do. Maybe take a quick peak at the tune (see attached) Thanks again!
St. Jude Donor '15
Add mass airflow [frequency] to list of channels you're logging, get another log and I'll show you what to change.
Basically need to change MAF table, but need to be able to see frequency it's outputting to know what areas to change
St. Jude Donor '15
Try these values for your MAF table. Make sure it's in g/sec before you copy/paste these in
Steve Haefner (10-18-2016)
St. Jude Donor '08
St. Jude Donor '15
(insert disclaimer about not responsible for blowing something up, etc. )
St. Jude Donor '15
Looks a lot better
