2005 cylinder volume
Received 1,194 Likes
St. Jude Donor '15
It's wrong from the factory but doesn't matter--probably just carryover from LS1/6
GMVE used on gen 4's already has cyl volume baked into it so the cyl volume field doesn't do anything anymore
St. Jude Donor '13-'14-'15
A 5.7 engine has a cylinder volume of 43.22 C.I.
PS why do you need to know ? are you swapping engineands or ECM's?
Because there are also many other tables that MUST be adjusted when swapping to a 5.7 engine or to a 5.7 ECM from a 6.0 ECM
Mainly the VE table is hugely different as are all the timing tables----Idle airflow tables- and most all the compensation tables for things like A/C--cold starts--shifting from P/N to drive etc
St. Jude Donor '08
We are done here.
